Discussing PI Intake Swap Cost in the 96-98 Forum. I have the intake and the heads and cams. I just want to put in ...
Old June 26th, 2008, 01:54 PM   #1
1997 Mustang GT
PI Intake Swap Cost
I have the intake and the heads and cams. I just want to put in the cams and intake for now. And down the road I might port the heads or do some sort of conversion. But, I want to know. How much is that stupid Heater Tube and Gaskets for the Intake swap cost. Its like $90 for the tube and almost $30 a gasket. That is more than I spent on the intake. Does this sound right?
Old June 26th, 2008, 04:17 PM   #2
nes
take 5/8ths heater hose (3ft) and some clamps and it will be fine, will cost about 10-15 bucks, and 30 for the gaskets is right
laser red 98 gt- stock
Originally Posted by supermachone View Post
psh dude i slit throats all the time
Old June 26th, 2008, 06:26 PM   #3
1997 Mustang GT
I have heard there may be an issue with the heater hose bursting. I don't want to half ass it, cause its expensive. $150 is not the end of the world, I just don't want to spend it if its not really necessary and i'm just getting taken advantage of by Ford, as they do that from time to time.
Old June 26th, 2008, 07:03 PM   #4
nes
HOW?? your other coolant hoses are heater hose, just do it, i wouldnt give you bad advice, those are just paranoid idiots
its not neccessary, i know alot of guys who have done it.
Old June 26th, 2008, 09:37 PM   #5
Uncle Humjaba's Avatar
1996 Mustang GT Premium
15.2@91
Just remember that ford had to make the coolant passage aluminum instead of plastic because it cracked. How much better would a rubber coolant hose work? Your decision.
"He is no fool who gives up what he cannot keep to gain what he cannot lose."
Old June 27th, 2008, 01:01 PM   #6
nes
are you assuming the coolant hose is gunna crack? the intake cracks from pressure if i recall, what kind of pressure is some heater hose gunna go thru causing it to crack? have u ever hit heater hose with a hammer? and then tried hitting a stock plastic intake with a hammer? the intake obviously shows no comparison to heater hose
Old June 27th, 2008, 01:16 PM   #7
MustangMatt96GT's Avatar
13.582@97.59 @ 5800 FT
Well i was a firm believer of never using the heater hose...
But im going to have to put heater hose in my Crown Vic motor because the block is slighltly different.
We expect shit to break, look foward to realizing exactly when it is happening, and than obsess about dropping plenty of cash to rebuild stronger, so we can try to run it hard as hell and break again. We are sick individuals.
Old June 27th, 2008, 03:10 PM   #8
nes
u shuldnt have been matt, that coolant tube leads into about 1 ft of heater hose anyway
Old June 29th, 2008, 10:13 PM   #9
15.2@91
look where that heater hose connects. it connects to the water pump. you dont think there might be some sort of pressure coming from the water pump? come on now.
Old June 29th, 2008, 10:18 PM   #10
Well as much as i would like to agree Uncle, but the water pump actually sucks right there, not push water...
But if i had the option which i actually do, i figured it out how to get the coolant tube to work on this crown vic motor, i would go ford parts. In a rush i could see heater hose working too...
Old June 30th, 2008, 12:18 AM   #11
nes
point
if the heater hose wouldnt stand the pressure, you think for would stick it there?
Old June 30th, 2008, 02:54 AM   #12
Ive had a heater hose bust on me before.. but i put another one there and is working fine. I think its just a matter of how old or new it can be. I think it will be fine for you to use.
2002 mustang v6- Auto, K&N CAI, Flowmaster dual exhaust, Black bullits dd
1996 mustang gt- 5spd, black, cobra hood, stock
November Birthday Club Founder
Threads Similar to: PI Intake Swap Cost
Cost of Trickflow Intake? RandoGT 96-98 13 April 1st, 2008 10:00 PM
PI Swap Cost midman 96-98 19 December 23rd, 2007 09:15 PM
PI Intake Cost! RandoGT 96-98 7 October 4th, 2007 09:58 AM
What Would An Engine Swap Cost For My Car OcOnnor220 99-04 15 September 1st, 2007 09:04 AM
Estimated cost on auto to manual swap Schizo995 99-04 5 August 19th, 2006 07:01 PM
