oil pressure to low at idle??
LinkBack (1) Thread Tools
Old June 27th, 2008, 03:17 AM   1 links from elsewhere to this Post. Click to view. #1
jasons_98gt's Avatar
1998 mustang GT
jasons_98gt is on a distinguished road
Send a message via Yahoo to jasons_98gt
hey all hows it going?
Got a 98gt with almost 150k well the oil pressure specs 25-40psi at 1500rpm while the engines hot which is fine cause i get between that and 60lbs while driving the only thing that concerns me is after driving for a while especially in the city at idle the guage is showing only 10-15lbs til i get back on the move...does this sound normal to anyone? any input would be great thanks
Old June 27th, 2008, 03:20 AM   #2
Proud American
MustangMatt96GT's Avatar
sounds like you could have some problems... i was showing 10-15 at idle and this is what happened to my motor...
The Beast Part 2
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
Never Lift Racecars
Old June 27th, 2008, 03:38 AM   #3
1998 mustang GT
did u motor make a slight knocking or clacking like noises when you did a cold start and go away after about a minute matt?
Old June 27th, 2008, 03:40 AM   #4
Proud American
not before... it blew up. BUt it also didnt have low oil pressure but at the track one night.
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old June 27th, 2008, 03:51 AM   #5
1998 mustang GT
well the mechanics arent diagnosing my oil pressure low because at a cold start its putting out almost 70lbs and when it under load the pressures all in specs only at 750 rpms its getting like 10-15 when its hot from like city driving and shit been that way for almost 2 years i figured he must be right or i woulda blown by now
Old June 27th, 2008, 03:45 PM   #6
1998 mustang GT
appreciate the input matt but im trying to get a few more opinions anyone?
Old July 1st, 2008, 09:36 AM   #7
MM's Drunken Sailor
deedub97GT's Avatar
single turbo in the works
as fast as i can push it!
deedub97GT is a splendid one to beholddeedub97GT is a splendid one to beholddeedub97GT is a splendid one to beholddeedub97GT is a splendid one to beholddeedub97GT is a splendid one to beholddeedub97GT is a splendid one to behold
Send a message via Yahoo to deedub97GT
oil pump on its last leg or a bad sensor some place tellin the comp it doesnt need that much oil at that certain time maybe
MILITARY CREW GSM3
Old July 1st, 2008, 01:55 PM   #8
StangAddiction is on a distinguished road
Send a message via Yahoo to StangAddiction
Oil could just be low... Have you checked the oil at least?
Old July 1st, 2008, 11:26 PM   #9
1998 mustang GT
yea i checked the oil and changed it as a matter of fact im not worried about it i had 3 mechs tell me today that its getting 12lbs at 750rpms which is good cause as a rule of thumb its like 10psi per thousand rpms like i said im not sweatin this lil shit anymore its been like that for 3 years if it was a problem the motor woulda burned up by now
Old July 2nd, 2008, 12:03 AM   #10
low oill pressure will make your bearings go bad... starvation ya kno... If you corner hard while on the gas you'll hear the bearings grinding if the oil is low.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/96-98/77751-oil-pressure-low-idle.html
oil pressure to low at idle?? This thread Refback June 27th, 2008 04:02 PM
Threads Similar to: oil pressure to low at idle??
low idle roush06 2005 - 2010 26 October 24th, 2007 08:13 PM
Low Oil Pressure 91lxhatch 5.0 Mustangs 2 July 29th, 2007 01:14 AM
kickout 7qt oil pan w/low oil sensor hole Iownastang 5.0 Mustangs 2 July 19th, 2007 02:17 AM
low fuel pressure blakeasaurusrex 96-98 18 July 6th, 2007 08:22 PM
low oil pressure kratos2250 5.0 Mustangs 4 March 1st, 2007 09:18 PM
