1997 SVT COBRA
1996 Mustang V6
![]() ![]() ![]() ![]() ![]() ![]() iTrader: 14 reviews
Biggest Cam's
Who makes he Biggest Cams for a 4.6.?
And What Are the specs on the cam's? Thanks in advance.
![]() -04 IRS - Magnaflow - Wheel Replica - Autometer - FTBR - FRPP - SCT - Brembo - PRO 5.0 - BOI- |
98 Mustang GT
11.9 @ 119
are you not doing the 5.4 anymore?
MM's Mad Scientist
Slow Fella
![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
What are you looking for?
1997 Mustang GT
Faster than an s4
Biggest cam is is a question of definition. You talkin Lobe height? or duration? or most extreme? There are alot of cam's out there. I've heard of cam's up to .7" of lobe height, on a really modified head. But that is the only one I've ever heard of. The highest I've seen made by Comp or Crower I believe is .575 Around that atleast is the biggest you will get that is mass produced.
1997 SVT COBRA
1996 Mustang V6
m talking the biggest off the shelf 4.6 cams With the specs on the box. just curious to what that might be i do not know if i will need a custon grind or not just trying to get some ideas together
Im still doing the 5.4 but i was under the impression that they do not sell after market cams for them like they sell for the 4.6s
#7 | |
1997 SVT COBRA
1996 Mustang V6
Bone stock 5.4 Other then bolt on's What do you guys think would be a good cam to run ? .575 i did not think they made mod cams with that much lift.
theres a dude on the board with a 99-04 gt and he put a 5.4 in it with a vt stage I cam the thing sounds beast i forgot who it is though
1997 SVT COBRA
1996 Mustang V6
Not always true, you have to calculate for usable rpm, static compression ratio, ect. You will need to be very specific on the combo you plan to run to get anything other than hear say. Most of the "BIG CAMS" require higher compression to even begin to be useful. AC or myself would be able to give you better direction knowing more about what you plan to run.
2001 Mustang GT
12.4@111 (N/A)
![]() iTrader: 1 reviews
not true. I have a set of custom grinds from MPH, the sound kinda mellow but make great power. LMK if you want a sound clip.
12.4 @ 111mph N/A 2V... (first trip out) in desperate need of a driver mod ![]() N2O times coming soon my junk at the track
1997 Mustang GT
Faster than an s4
What Boomer and AC are saying is that Bigger is not always better for cams. Cams are just what make your air pump(engine) run a certain way. A cam designed specifically for your set up will make more power than any other option. And if you have a mild set up compression and rpm wise, a big cam might not even get into its efficiency zone with your set up. You want a cam that matches your build. A mild build needs a mild cam. A nutz build will need a nutz cam.
Aztec Gold 97GT. MM CC Plates, Panhard Bar, SFC's & Tower Brace Eibach Sway Bars H&R Race Springs/Bilstein Shocks MAC CAI, LT's, Catted H and Pro-Dumps KB Boost-a-Spark 04' PI Motor Author of The Official Suspension Guide |
MM's Mad Scientist
Slow Fella
4Point^, just let me know exactly what you are building and what your goals are. I can get you a pair of cams that are as radical as you want to go on a given set-up. Plus, you will have technical help within close range......
2001 Mustang SVT Cobra
^True. He's done and will do mine again, very shortly.
Slow, really slow Cobra. Wanna see?![]() MM Cobra Club Member #81 "TAMPA BAY AREA CREW"
MM's Mad Scientist
Slow Fella
Also, to answer your question, Crower makes the biggest lift cams available off the shelf. They also make shit for power as far as I have seen on NA motors. I know of one blower motor with Crower cams that makes awesome power, but that car spends more time being worked on than anything. The problem with Crower is that they use a rediculous lift (.620" on a few grinds), medium duration and slow ramp rates. Most 2V heads don't pick up much air flow over .525" lift and without an aggressive ramp rate, and the cams are not staying near peak lift long anyway. There is more to camshaft profiling than slapping a huge lift/duration on a billet and making power........
1997 SVT COBRA
1996 Mustang V6
No no im not saying Big Cams Big Power .
Im trying to say i want to make the most out of the cam as i can and i want big cams not big big like somthing that sounds like a pro street car and makes no power. i have had cammed cars and learned big cams are not always the best.but im am still kinda new to the cam world with modular motors. Basicaly its going to be a Stock 02 5.4 290ish hp 330ish /with Bolt On's. I wanted to get the best cam to make the best power.
1997 SVT COBRA
1996 Mustang V6
Bolt On 5.4 Want to make the car run its best on the motor with just bolt on's and cam's s.Let me know what you think.
1997 SVT COBRA
1996 Mustang V6
Any idea's A.C
MM's Mad Scientist
Slow Fella
1997 SVT COBRA
1996 Mustang V6
i sent you an email.
Threads Similar to: Biggest Cam's
| what is the biggest tire | bigwhiskey | 5.0 Mustangs | 8 | September 10th, 2007 07:37 PM |
| Biggest Wheelsize for a 88-93 GT | Nociznice | 5.0 Mustangs | 7 | March 21st, 2007 08:19 PM |
| Which Tire Is Better And What's The Biggest | psycho bob | 2005 - 2010 | 3 | November 9th, 2006 01:24 AM |
| The Biggest Retard | jealousy | Videos | 8 | October 13th, 2006 08:22 PM |
| my biggest turn on | sAJ1420 | Multimedia | 9 | September 18th, 2005 09:48 PM |
