Discussing Confused... Need Help Plz! (PI Manifold Stuff) in the 96-98 Forum. Ok, first off I know you guys are probably sooo sick of hearing people ask ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Ok, first off I know you guys are probably sooo sick of hearing people ask for help with Npi to pi intake manifold swaps, but I just have to ask. First off, my stock intake manifold is cracked right at the thermostat housing, and I basically need to get a new one. My cousin said that its pointless to get a pi intake manifold for my 96 GT because it creates a "snowball" or "domino" effect where that once you start, you have to start replacing EVERYTHING because the air to fuel mixture is messed up now. He also said that it might even make my car run worse... so my first question is... would it be stupid to buy the PI manifold for my 96 GT? It just seems that if I'm going to be spending the money I might as well get performance out of it... My other question is, is there a walkthrough somewhere that goes step-by-step how to replace an intake manifold on a 96 GT? I have a chiltons and haynes manual, but those just seem to be good enough to get me in over my head and waay confused.
Thanks in advance, and sorry for repeating this over-asked question. Zac |
2000 mustang gt
11.79@115.83
a pi intake swap isnt that bad. most manuals will have a step by step instructions. the intake realy needs the matchine heads to be of any use. in no way will the intake ports match the ports on the heads. they will line up but the openings are not the same.
stock long block, bolt ons, slicks, and a little squeeze N/A-12.81@103.7 N2O-11.79@115.8 parting out 04 cobra, pm me for details |
MuchCoolerThanGTsetGO
SLOW
I would disagree with your cousin. casper did an awesome writeup on how to swap them let me see if i can find it. the only thing you gota do drill an tap another hole in the coolant crossover on the front of the intake. the PI has one hole and your NPI intake has two its actualy realy simple hmmm let me see if i can find that post
ok, thanks so much for all the input. Just wanna make sure i do the right thing
Zac,first word of advice is dont listen to your cousin. I have found that if people cant give you a detailed or exact reason not to do something ,they are basically shooting from the hip . You dont have to replace EVERYTHING . A few things need to be swapped,but their are kits for this. And its a big improvement power wise over what you have,
There is not a significant enough change in this upgrade to mess up your air/fuel mix. If you really wanna make it worth your while ,get the heads and cams to. You can usually pick them up for around $300 . p.s.- Whatever intake you get,be sure to get the aluminum crossover. |
where did u find pi heads and cams for 300 bucks?
EBAY just keep an eye out i actualy just saw a set of complete PI heads (heads cams valves springs) for under 280 sell just a few weeks ago
#10 | |
jeeze, wish i could get that lucky haha last time i checked those heads alone were going for like 1,300
1300 for stock oem PI heads is a rip off dont buy them for that you can easily find them cheaper on ebay
96 GT , cams,intake manifold,CAI,Exhaust,Full Hotchkis suspension, and many more |
SLOW
You can find them for $300 around ebay and on alot of these forums...
I had a set-up for sale for all of 3 minutes and someone on here called the parts quickly... |
I'm getting my whole PI Kit from JEGS, just above $1000 shipped for everything including the manifold, heads, and install kit...
...Modded 1996 Ford Mustang GT... SOLD!!
...Modded 2001 Ford Mustang SVT Cobra... SOLD!! Now... ...Modded 2003 Ford Mustang SVT Cobra, Anniversary Edition.. www.cardomain.com/id/po1snd_u |
#15 | |
SLOW
Threads Similar to: Confused... Need Help Plz! (PI Manifold Stuff)
| I'm a little confused... | D-Brow | Exhaust | 4 | July 26th, 2007 08:25 PM |
| No name single plane manifold VS Victor Jr manifold | hitorx | 5.0 Mustangs | 5 | May 11th, 2007 09:47 AM |
| confused | mustang1072 | Engine | 5 | December 27th, 2006 10:55 AM |
| confused | midnightrace | 99-04 | 2 | December 4th, 2006 03:39 AM |
| Swapping a 98 V6 intake manifold with for a 99 V6 manifold | 98mustang | V6 Mustangs | 5 | September 24th, 2005 11:27 AM |
