fuel delivery prob.
Old June 30th, 2008, 10:42 AM   #1
1998 GT
vortech4.6l is on a distinguished road
fuel delivery prob.
okay im not getting barely any fuel at high rpms.... i thought it was because my fmu wasnt hooked up. but i hooked it up and im still not getting more then 38lbs of fuel with 9psi boost. im blowing carbon smoke out the pipes at high rpms too. it runs smooth untill i get about 4500 rpms. do you think it could be a clogged fuel filter or something worse.
Old June 30th, 2008, 04:14 PM   #2
ModMustang97GT's Avatar
1997 Mustang GT
Faster than an s4
ModMustang97GT has a spectacular aura aboutModMustang97GT has a spectacular aura aboutModMustang97GT has a spectacular aura about
Carbon out the back means your running rich. Light smoke means lean. At high rpm your fuel pressure will drop due to higher manifold pressure. Do you have an upgraded pump or boost-a-pump? All those things contribute.
Old June 30th, 2008, 07:42 PM   #3
1998 GT
well my vortech external pump went out today when i was changing the filter. so now im only running 25psi fuel. okay so black means rich my plugs are redish though...
Old July 1st, 2008, 01:31 PM   #4
1997 Mustang GT
Faster than an s4
Redish? I've never seen that. You have got to be burning some sort of additive. Generally its white or black. I have seen a small brown color. I believe the plug was running hot. What does the electrode look like? Coroded, dotted, dark, clean?
Aztec Gold 97GT.
MM CC Plates, Panhard Bar, SFC's & Tower Brace
Eibach Sway Bars
H&R Race Springs/Bilstein Shocks
MAC CAI, LT's, Catted H and Pro-Dumps
KB Boost-a-Spark
04' PI Motor
Author of The Official Suspension Guide
Old July 1st, 2008, 05:04 PM   #5
1998 GT
dark, well ive been messing around with it all day, the pump works okay but im only reading about 32 max fuel psi, but when i rev up the engine the fuel gauge drops to like 5to8psi. im not knowing much about this whole thing but do you think its my regulator?
Old July 3rd, 2008, 07:41 AM   #6
1998 GT
i dunno what to do guys, ive tested both the vortech trex pump and the stock pump they both work, the only other think i can think of is my fmu but i dont know how to test it...please any help or experiancce would greatly be apprieciated.
Old July 3rd, 2008, 08:34 AM   #7
1996 Mustang GT Vert
Blower Head is on a distinguished road
The function of the FMU is to slow the flow of fuel back to the tank under boost and thus increase fuel pressure. If you can unplug the vacuum line from the FMU with the car running and apply a small amount of air pressure (5-10 PSI) to the port you should see your fuel pressure increase. If that does not happen I would suspect the FMU has a leak. I have a new one I didn't use on my Mustang if you discover yours is bad I would be willing to sell. Otherwise maybe it is time to consider a tune with 42# injectors and a 90 mm maf as I am running and get rid of that FMU!
96 GT vert, Aftercooled Vortech, Lightning MAF,42# injectors, saleen cams, Bullitt intake, tune by Hitech, Magnaflow catback and O/R xpipe, Cobra brake upgrade, lowered bilstein suspension w/MM c/c plates and subframe connectors 3000 stall and 3.73's
Old July 4th, 2008, 07:45 AM   #8
1998 GT
well i just baught this car from my dad and when i took it to the shop to get it looked at he told me why i wasnt using my fmu because it wasnt plugged in, so i plugged it in and now it feels like my car is missing at about 4500rpms and on/. do you think he he wasnt running the fmu on purpose?
Old July 11th, 2008, 10:04 PM   #9
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
He's your dad dude, why don't you call and ask him? While you still can.
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Threads Similar to: fuel delivery prob.
Fuel Delivery Emay 2005 - 2010 13 June 6th, 2008 09:28 AM
prob mpboy 99-04 1 March 5th, 2008 09:46 PM
fuel delivery 01silversnake 4V / SVT 33 February 3rd, 2008 09:47 PM
Fuel Prob hopper 5.0 Mustangs 7 December 19th, 2007 08:24 PM
Air Delivery MattB 5.0 Mustangs 2 August 22nd, 2006 06:47 PM
