1997 Mustang GT
Rear brakes and Rotors
I have a 97 GT with all around disc brakes my question is... How hard is it to change out the rotors and breaks in the rear. I keep hearing different things just want to get some real info on this......
Any info would be appreciated!!!!
![]() 1997 Mustang GT 1985 Mustang Gt 5.0-Sold |
It's pretty damn easy, i did rotors and pads on my car in about an hour and a half.. and that includes cleaning the calipers. Its really not bad at all dude.
![]() Cammed 2v Built By MustangMatt More mods than times your daughter has slept around |
oh, and don't get Autozone's duralast rotors, they got surface rust on them in less than 3 months.
1997 Mustang GT
Is it just as easy as take off and putting on or are there bearings you need to switch out or anything like that?.....
No dude, thats all further back. Everything just unbolts.. you will need to borrow a tool that clamps the caliper tho.
1997 Mustang GT
What like the c clamp.....
Yea, that will probably work, there's a special tool that you can rent thats made for it.
1997 Mustang GT
Thanks bro really appreciate it just didnt want to tear it apart and not know what i was getting myself into... Thanks
1998 Mustang GT
Rear brakes
I am installing the Cobra rear brake kit next week, I will try to remember and let you know how it goes.
K |
you can use a simple c clamp. they do make a tool that makes it a tad easier though. rear breaks are easy.
Priest of the Car Gods
and "lifetime warranty" pads are a joke. The "lifetime" they refer to is just the lifetime of the pad, and they're usually made of some hard-ass material that just eats your rotors. If you're not going to something like a Hawk, EBS, or Porterfield (which you really don't need in the rear), just get the basic pads.
O o /¯/______________________ |BLAAAAAAAAAAAAAAAAAAAAAAAAARGH!!! \_\ Buy my Bronco, special deal for MM folks |
#12 | |
its just 4 bolts and when u se the c clamp be sure to use the old pad to push it in so u dont push in one side and not the other and thats about it but clean the new rotors with brake clean before u put the on to take some of the film off.
2 bolts if you just take off the entire assembaly.
true but alot easier to clean if its all taken apart
1997 Mustang GT
Faster than an s4
Use a C clamp, the little Tool that makes it easier is trash and broke when I used it. Open your brake fluid reservoir and clamp down on the piston of the caliper, if it doesn't push right in, give it a second and it will go down, just keep pressure on it untill it sinks low enough. And on the rear brakes, you need to watch for the E brake cable. Its a pain to get around, the ford designers were retarded on this one, but you can get by it easy, use a long handle 15mm and you will be done in no time. Its really easy, no bleeding necessary or anything. As for resurface rust, that happens to all brake rotors if you let them get wet and sit for a while. Comes off as soon as you use em once.
Aztec Gold 97GT. MM CC Plates, Panhard Bar, SFC's & Tower Brace Eibach Sway Bars H&R Race Springs/Bilstein Shocks MAC CAI, LT's, Catted H and Pro-Dumps KB Boost-a-Spark 04' PI Motor Author of The Official Suspension Guide |
Threads Similar to: Rear brakes and Rotors
| Rear rotors | shurb125 | 5.0 Mustangs | 5 | May 5th, 2008 10:00 PM |
| Need Rear Stock Rotors... | jat | 2005 - 2010 | 20 | November 19th, 2007 04:18 PM |
| Brakes (Installing Rotors and Pads) | terribleonexx88 | 5.0 Mustangs | 36 | September 9th, 2007 09:00 PM |
| Wher can i get resonable sloted an drilled rotors and brakes | blown96stang | V6 Mustangs | 15 | June 2nd, 2007 04:09 AM |
| Rear Rotors and Rear Axle | rondaw3g0410 | 99-04 | 1 | September 6th, 2006 11:00 PM |
