Discussing gt vs cobra in the 96-98 Forum. whats the difference engine wise between the 96-98 mustang gt and cobra?... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
gt vs cobra
pretty sure the cobra was still a 4v even in that year
Foxlake stage 2 heads, CMS stage 2 cams, Custom Diablo tune, BBK LT's, BBK O/R H, Bassani Race Mufflers, MGW STS, 75MM TB, K&N CAI, Eibach Sportlines, 4.10's Mineral Gray Club Member #1
91 Sonic Blue Goodness
19.83 @ 12mph
it was a 4v.
305 HP vs 225 |
1997 SVT Cobra
Cobra's 4-Valve engine tops the GT 2-Valve. My friend had his 97 Cobra's hood open next to my 96 GT and the size of the engine, heads and everything on the Cobra is so much bigger than the GT, hah it made me feel bad.
yeah i know that they are the 4v but what is it just the gt40 heads and different manifold?
19.83 @ 12mph
neither.
it's a 4.6 not a 5.0 it's a modular motor. |
oh yeah..that was a stupid thing for me to say. so can you put the cobra heads and intake on the gt. the blocks the same right
19.83 @ 12mph
yes you can but it takes a hell of a lot of work.
#9 | |
+1 its a hell of a job to do a 4v swap u basically need to have a compete engine
2004 GT FOR SALE http://www.moddedmustangs.com/forums...tml#post927678 ![]() Cat Club Co-Founder |
1997 Saleen S281
The 96-98 cobra was rated at 305 hp compared to the 96-98 gt (rating at 215hp.) The cobra has larger heads and 4 camshafts as well as a better intake, larger mass air meter and 24lb injectors compared to the 19lb injectors on the gt. It also has a better brake package (i.e. 2 piston calipers up front with 13" rotors). It is possible to convert your 2 valve gt block to accept 4 valve heads and intake but it would be more beneficial to purchase a new aluminum cobra block and start from there.
Look Ma! My First Post!
wait wait wait the block size in 96-98 was the same 4.6L cobra or not. the last year they had 5.0 was in 95
thanks that helps a lot, so basically if a get a 96-98 mustang go for the cobra
1995 Mustang GT
^ that would be correct... Cobra FTW
GT40 "P" heads, 1.7 Roller Rockers, GT40 upper/lower, MAC long tubes, MAC o/r h-pipe, Flowmaster 40-series, 65mm t/b, 'C' Springs, '03 Cobra Bilstein Struts, Tokico Bullitt Shocks, MM Caster/Camber Plates
1998 Mustang GT
96/97 was rated at 215 hp, 98 was rated at 225 hp because of a better ehxaust manifold. Nothing else changed inside the engine,all 3 years had the same cams,pistons,ect.
1998 Mustang GT/ 2007 Mustang w/Pony Package
97 GT
A Burnout got me her^
Yeah, if you want major power, get a Cobra.
![]() 1997 GT|PI Intake|Spec 1 Clutch|BBK CAI|3:73's|SLP LM1's|O/R H Pipe|Mishimoto Radiator|Steeda Tri-ax |Cobra Hood|Bullitt Rims|Eibach Prokit|H&R Spacers Soon to have: Matt's 27k PI converted engine with Comp 270's PI Romeo Heads for sale |
2000v6/soon 5.0=]
15.45@88.37mph
![]() 99 svt cobra rims/cai/autolite plugs. Soon to have a 1990 mustang gt fox ![]() |
1998 mustang gt
1/8= 9.3@ 78
i thought they changed the blocks to romeo instead of a windsor 98?
Master of the Force
Millenium Falcon
"Just Living the Dream"
still the same block, just made by a diffrent manufacturer
MSO smokes pole |
1997 Saleen S281
Naw man, same manufacturer, different location.
Master of the Force
Millenium Falcon
MSO smokes pole |
Threads Similar to: gt vs cobra
| Wanted : 18X9 y2k cobra rims for 1997 cobra | cobrarob | 96-98 | 7 | September 17th, 2008 11:01 AM |
| evo vs LS1...Cobra vs Camaro...Cobra vs Cobra | Racerchik02 | The Clubhouse | 9 | April 28th, 2008 10:51 PM |
| which engine for 1500 rwhp 2003 cobra 1999 cobra or 2000 gt | gtjason | New Members Introductions | 8 | March 11th, 2008 09:24 AM |
| WTB: Longblock, Cobra, Mustang, Explorer, F150 3v Parts and Cobra TB, TB Cable | 94stang | Want to Buy | 2 | February 18th, 2008 03:19 PM |
| Cobra R brakes with 2003 10th anniversary cobra wheels...? | Gen1sve | 99-04 | 9 | April 26th, 2007 06:24 PM |
