think i finally fixed it
Old August 3rd, 2008, 11:45 PM   #1
zigbigadoru's Avatar
97 Mustang GT
slower than the speed of smell
zigbigadoru will become famous soon enoughzigbigadoru will become famous soon enough
so my idle has been all messed up, as in it hung at like 1500rpm every time i used the clutch. so i finally just went to murrays and got a new tps and hopefully that fixed it. btw can you adjust the old tps, cuz i couldnt figure out how.
Old August 4th, 2008, 12:38 AM   #2
97GT4.6's Avatar
97 GT
14.2@99.8 @ 4800 ft
97GT4.6 has a spectacular aura about97GT4.6 has a spectacular aura about97GT4.6 has a spectacular aura about
Send a message via AIM to 97GT4.6
You also might want to clean your IAC and MAF as well, that can also make it idle and run better.
Cammed 2v
Built By MustangMatt
More mods than times your daughter has slept around
Old August 4th, 2008, 01:06 PM   #3
97 Mustang GT
it wasnt that, seeing as i have alrdy tried it.
Old August 6th, 2008, 12:29 AM   #4
97GT4.6's Avatar
97 GT
14.2@99.8 @ 4800 ft
If you get a 40 dollar IAC spacer, that will help it drop to idle a lot faster. im gonna buy one.
Cammed 2v
Old August 6th, 2008, 12:34 AM   #5
steeda98's Avatar
1998 Mustang GT
steeda98 is on a distinguished road
check the screw on ur throttle body and the cables too..mine did the same when i replaced my tb with a 75mm..it was the cable gettin stuck...but im really not sure with ur issue
P.I. H/I,TF Stage 1 cams, Comp valve springs and retainers Steeda headers O/R X w/ SLP LM1
JLT CAI w/75mm TB and Plenum, Koni Adj. Steeda plates, lower control arms, rear strut brace,3:73, FRPP driveshaft, SCT tune, TF Underdrive Pulleys
Old August 6th, 2008, 04:11 PM   #6
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
no, the tps is not adjustable.
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Old August 7th, 2008, 04:55 PM   #7
ModularSteed's Avatar
1997 Mustang GT
335rwhp/370rwtq
ModularSteed is on a distinguished road
+1
97 GT|Full PI Swap|BBK UDP|C&L Upper Plenum|Flowmaster Exhaust|O/R H|3:73|B&M|SCT X3|NOS 75|Eibach Pro Kit|99 SVT Wheels|
Originally Posted by 330CubeGt View Post
On a serious note i would try some vasoline and is should wiggle right in.
Old August 8th, 2008, 05:11 PM   #8
Trick Tuners's Avatar
KB'd GT
My bet is that the TB plate needs to be closed a little more. Especially if the problem started after messing with the TB. You may also have a vacuum leak, so rule that out if you were not messing with the TB, but did mess with the motor. The TPS can slightly be adjusted due to some slack in the bolt holes. If you punch out the metal inserts, you can adjust it more. It really needs to be between about .93 and .99V, but less than 1V and you should be fine. The ecu will calibrate it on every startup and all TPS calculations are based off of closed throttle.
Threads Similar to: think i finally fixed it
fixed it! e3sean 5.0 Mustangs 4 June 22nd, 2008 05:32 AM
Finally Getting My Car Fixed! Dansby The Clubhouse 2 December 10th, 2007 12:55 PM
ok can this be fixed? LXstang5.0 Visual 1 November 10th, 2007 04:20 PM
fixed it 232stang The Clubhouse 0 July 31st, 2007 02:21 AM
Brake problem fixed, finally. TheUNZippee! 2005 - 2010 6 June 24th, 2007 02:18 AM
