Discussing post got me thinking.... in the 96-98 Forum. So stanglifemike's post about the 5.4 2valve got me thinking about my own ...
Old August 6th, 2008, 03:32 PM   #1
97S281's Avatar
1997 Saleen S281
So stanglifemike's post about the 5.4 2valve got me thinking about my own engine build.
I was planning on boring a 4.6 block .030 over, getting it magnafluxed and cleaned up then adding a forged stroker kit with forged rods and 18.1cc dished pistons. Iv'e already ordered a set of stage II heads with comp cams stage II blower cams and beehive springs. And I have already purchased and recieved a saleen series II roots style supercharger kit with an intercooler. And Iv'e got an extra pulley that will give me 9-11 lbs of boost instead of the stock 6-8 lbs.
But you can buy a brand new FRPP 5.4 block and a new forged svt lightning crank for about the same as the block work would cost.
So, does anyone know what parts would swap over from a 4.6 motor to a 5.4 motor?
I am considering it seriously, because as we all know there is always more power to be had from more displacement.
Old August 6th, 2008, 04:00 PM   #2
NMR-2vGT's Avatar
the heads, cams, intake should all swap over
1996 Mustang GT, Full PI Swap, MGW Shifter, Magnaflow Cat-back, K&N Filter
Former name: Lethal2v
Old August 6th, 2008, 07:51 PM   #3
No on the intake, different deck height. The heads,cams ,piston ,flywheel and oil pump are just a few of the items sharred by the two. When switching to a 5.4 block be aware that the compression will be lower unless you plan to run a smaller cc dished piston. 5.4 are fun they make a little more torque, with a 2 valve head your really not going to see much more for the money. I am only being honest, the added nose weight on the car almost balances out the difference in power (N/A). Building a big bore 4.6 is going to be a better option for the money, power to wieght and power to cubic inch. By the time you build a decent 5.4 (2v) you would be further ahead doing the 4.6 (big bore).
Old August 6th, 2008, 07:53 PM   #4
NMR-2vGT's Avatar
I forgot the intake isnt a direct swap, but i think you can get some adapter plates for the intake to swap it over. But i agree with boomer on the fact that it would be a better idea to build a 4.6
Old August 7th, 2008, 12:34 AM   #5
jlaw98gt's Avatar
^^^^rocks acoustic when drunk
build what you want to build dude...
Old August 7th, 2008, 03:39 AM   #6
97GT4.6's Avatar
97 GT
A Burnout got me her^
I say find yourself a DOHC 5.4 and then you're set.
1997 GT|PI Intake|Spec 1 Clutch|BBK CAI|3:73's|SLP LM1's|O/R H Pipe|Mishimoto Radiator|Steeda Tri-ax |Cobra Hood|Bullitt Rims|Eibach Prokit|H&R Spacers
Soon to have: Matt's 27k PI converted engine with Comp 270's
PI Romeo Heads for sale
Old August 7th, 2008, 11:11 AM   #7
97 Cobra
The lighter engine can make similar power.
In the land where weight is the #1 enemy I'd say shave it wherever you can and go with an aluminum teksid 4.6 4v.
Weight savings are ALWAYS linear in terms of gained performance. You can have a 9 second car that will see a decent gain from losing some weight. Adding power at that level becomes less and less responsive in your timeslips however. The key is efficiency. Getting the most out of the power you make is where its at.
Of course it will be a fun car either way. I've heard those 2v 5.4s arent much behind the 4v 5.4s anyway until you reach serious power levels.
Good luck
Old August 7th, 2008, 07:51 PM   #8
97S281's Avatar
1997 Saleen S281
it's a little late to go to a cobra setup as i have already purchased the heads cams, and supercharger.
But considering i wouldn't be able to use the s/c on the 5.4, i think my mind is made up.
Thanks for all the input, I think my direction is clear.
Old August 7th, 2008, 07:54 PM   #9
97 Cobra
Ahh ic.
Like I said that will still be a wicked fun car.
Pics when you finish it.
Cheers
Old August 7th, 2008, 10:07 PM   #10
97GT4.6's Avatar
97 GT
Can't wait to see what you are going to do with your build.
Threads Similar to: post got me thinking....
Also, now that I am thinking about it.. Dawgfude03GT 99-04 4 May 4th, 2008 02:10 AM
got to thinking whitemustang02 The Clubhouse 26 April 15th, 2008 07:24 PM
I know what your thinking. (Where's he been?) jdansby1 The Clubhouse 19 January 25th, 2008 07:13 PM
thinking about it.... trueballerisme Electronics 17 September 18th, 2007 02:23 AM
thinking about getting a 232stang All Other Vehicles 8 February 9th, 2007 07:02 PM
