Discussing 5.4 4valve in the 96-98 Forum. can a 5.4 4valve fit in a 97 mustang gt? wut vehicles come with ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
1997 Mustang GT
5.4 4valve
can a 5.4 4valve fit in a 97 mustang gt? wut vehicles come with the 5.4 4valve? how much would a 5.4 4valve be (used)? would everything from a 4.6l swap over, as in cai, supercharger, intake manifold, headers, catback, etc?
#2 | |
there is a lot involved and not really anything can be reused... they came in navigators they are around 3000 used
2004 GT FOR SALE http://www.moddedmustangs.com/forums...tml#post927678 ![]() Cat Club Co-Founder |
1998 SVT Cobra
The word is "what", and you'll probably have better luck asking this in the 4v section.
*The Sacred Chao says "MU"* Real racers turn corners... both ways... on the same track. MM Corner Carvers Crew, member #2 |
2000 V-6
No...
The easy answer is no... There is no easy way to fit the 5.4L 4V in a mustang, any of them really. It took SVT over a year to get one into production (the 2000 Cobra R has a 5.4L in it). It is a truck motor, it was designed for a truck, not a sports car, but if you really want to know what all would be involved, here goes. 1 - You'll want a tubular k-member 2 - new springs and struts to account for the weight up front 3 - motor mounts 4 - headers / manifolds will have to be fabricated 5 - intake manifold will have to be fabricated 6 - modify the strut towers to accomodate the 5.4 7 - A/C delete, as I don't believe that it can be used due to the larger motor 8 - New bell housing, and possibly new tranny (if it's a manual, a T-56 would be best, but I believe that a 3650 will handle it. 9 - ECU 10 - T/B and plenum for 5.4 and custom intake 11 - Radiator would be a good idea 12 - Strut tower brace can no longer be used due to the intake 13 - New / custom CAI 14 - MAF for 5.4L (I think the Lightning could work, maybe wrong though) 15 - Hood, hi-cowl (3"+ to clear the intake) I am SURE I am missing things, but this should give you an idea of what would be entailed in doing a 5.4L swap. You would be better off just going to a 347 stroker motor and K-member, that would be a better choice IMO |
1997 Mustang GT
damn, i suppose its the same probelsm with a 5.4 2 valve? and wuts this 347 stroker? is it a whole new shortblock/long block? or does it just modify the 4.6L with a longer stroke and what not?
97 Cobra
Modifies the 5.0 pushrod to 347ci or 5.6 liters.. I believe the aluminum 4.6 can be stroked plus bored to get around 5.3 liters.
#7 | |
1996 Mustang GT, Full PI Swap, MGW Shifter, Magnaflow Cat-back, K&N Filter Former name: Lethal2v |
2000 V-6
No, I just believe that you have to convert to either manual or hydraulic brakes.
but about the 347 stroker: It is a stroked 302 / 5.0L They make a significant amount of power and with the plethora of 5.0L motors out there, they are fairly cheap to make / install. The only real modification that you would need that I can think of is motor mounts, ecu, and intake parts + your choice of the many exhausts available for the sn95 from 94-95. |
1997 Mustang GT
wow no fuck that. ill just stick with the 4.6L. wow so gay you cant do anything with these engines..... if i wanted a 5.0 i would have GOTTEN a 5.0
It's actually very easy to do either a 4v or a 2v swap. I have a 2v 5.4 in my 03, it's cake and makes great power on the street.
2v is much easier than 4v on a car that started as a 2v for obvious reasons. If you want the correct answers from someone that's actually done it, come on over to mustangboards.com and check the 5.4 swap sticky in the 4.6 tech section. We have better than 10 guys with running 5.4 equipped cars. I'm having longtubes made now.. if we get more people to sign up for them then they'll be made for retail sale. |
BTW... a basic swap requires only adapter plates for the intake and a quick trip to the muffler shop with your h-pipe. The rest is a DIRECT bolt in.
Threads Similar to: 5.4 4valve
| 4valve heads | Toph6888 | 99-04 | 5 | May 6th, 2008 10:33 PM |
