Discussing New fuel injectors help in the 96-98 Forum. Alright guys give me some advice here, this is where I am clueless. I want ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
1997 Mustang GT
Alright guys give me some advice here, this is where I am clueless. I want to put new injectors in but unsure what size I can safely go up to. Sometimes I think my chokes when I hit the throttle due to the lack of fuel intake. Maybe in my head. WOT is no problem! Anyways if this or isn't the problem I still want new injectors. So with the mods listed below, tell me what is safe! Thanks in advance for any help!
Current mod B&M shift kit 3.73 gears Steeda under pulleys BBK CAI BBK 70mm spacer Accel Coil Packs FRPP 9mm wires NGK Iridium plugs Royal Purple Oil Steeda lowering springs on 4 corners X-CAL 2 with 93 tune from Amazon racing Flowmaster Delta Force II mufflers Pypes x-pipe with high flow cats |
1997 Mustang GT
That delay you are talking about is more likely the engine getting too much fuel when you mat the peddle. If when you pound it, it seems to take a bit of time to actually get up to RPM, it has to do with the way your engine is tuned. As for injectors. You can put F***N huge ones in as long as you get it tuned for it. Most hand helds only support up to 42 lbs. ones before you have to get custome tuned.
Aztec Gold 97GT. MM CC Plates, Panhard Bar, Subframes & Tower Brace Eibach Sway Bars H&R Race Springs/Bilstein Shocks MAC CAI, LT's, Catted H and Pro-Dumps KB Boost-a-Spark PI Swap Spun Main Bearing... |
Threads Similar to: New fuel injectors help
| 19 lb/hr fuel injectors | lilgreenstang | 2.3 Mustangs | 2 | May 3rd, 2008 10:56 PM |
| Fuel Injectors | Mach Boy | 99-04 | 3 | November 7th, 2007 09:32 AM |
| Fuel Injectors/fuel pressure | 00silvergt | 99-04 | 4 | August 2nd, 2007 10:54 AM |
| New Fuel Injectors | 1998_svt_cobra | 96-98 | 22 | February 19th, 2007 10:24 AM |
| Fuel Injectors | RC02GT | 99-04 | 3 | October 9th, 2006 08:44 AM |
