LinkBack (1) | Thread Tools |
#1
1998 mustang GT
running lean
can someone help me w/this. ever since i installed my supercharger my check engine light goes on for a while and then off for awhile. i pulled a code and it said fault sensor in bank 1, so i changed the sensor but it's still doing it. the code also read the car was running lean, so what should i do for adjustments to fix this? thanks, ron
98 gt blk on blk 90k miles with BBk 75mm throttle body, C&L plenum, Diablosport predator,powerdyne supercharger & a few other things. |
48.47@ 12.58
you have fuel upgrades?
1998 mustang GT
only a boost pump..
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
you dyno tuned or canned tuned?
1998 mustang GT
it was tuned on a dyno with my diablosport tunner. i think that the timing is retarded like 10 degrees i'm not sure if the fuel was adjusted(i don't remember).
LinkBack to this Thread: http://www.moddedmustangs.com/forums/96-98/86659-running-lean.html
| running lean | This thread | Refback | August 29th, 2008 09:20 PM | |
Threads Similar to: running lean
| running lean | silvergtstang99 | 99-04 | 4 | May 27th, 2008 06:21 PM |
| Running Lean | 1982matthew | 5.0 Mustangs | 2 | April 23rd, 2008 04:01 PM |
| running lean | 91cobra5.0 | 5.0 Mustangs | 26 | January 24th, 2008 09:59 PM |
| Running Lean | ROUSHME661 | V6 Mustangs | 22 | November 30th, 2007 01:47 PM |
| RUNNING LEAN !!!! | 97MUSCLESTANG | Modular Mustangs | 6 | March 5th, 2007 09:03 AM |
