4.6 big bore?
LinkBack (1) Thread Tools
Old August 30th, 2008, 03:45 AM   1 links from elsewhere to this Post. Click to view. #1
product1620's Avatar
98 GT
14.60 @ 94.78mph
product1620 is on a distinguished road
Send a message via AIM to product1620
4.6 big bore?
ok, so google didn't turn up much information for me, im looking for information about 4.6 to 5.0 big bore engines. I'd really like to see a build thread and or information about the build. Thanks
1998 GT
FRPP: 4.10s, Alluminum d/s
STEEDA:upper/lowers, springs, cc plates, tri-ax
TOKICO: Adjustable shocks
SPEC: alluminum flywheel
K&N: Intake
Screamin Demon ignition
ram: clutch
BUCK OFAMA
Old August 30th, 2008, 10:43 AM   #2
Boomer is on a distinguished road
Send a message via AIM to Boomer Send a message via Yahoo to Boomer
There is not all that much to dig up. The block get machined to hand cylinder sleeves that allow a 3.70" piston to be used. Increasing the size of the cylinders adds the cubes and unshrouds the valves to allow the engine to breath better. I am not really sure what information other than than you are looking for.
Old August 30th, 2008, 12:54 PM   #3
1998 Mustang GT
Need to hit the track
RandoGT is on a distinguished road
Houston Performance has a big bore stroker 2V if you wanna learn more about it. contact them
Old August 31st, 2008, 12:00 AM   #4
98 GT
14.60 @ 94.78mph
So basically your resleving the block with oversized sleves? From what I saw there are companies that will do the work for you or sell you a short block, but I havent seen just the oversized sleves and pistons for sale, I'd like to have a local machine shop do the work, instead of sending a block halfway arond the country and back.
1998 GT
K&N: Intake
ram: clutch
BUCK OFAMA
Old August 31st, 2008, 12:02 AM   #5
Proud American
MustangMatt96GT's Avatar
It has to be an aluminum block to get it sleeved, and Darton makes the sleeves
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
25.3 SFI Chassis Build
Never Lift Racecars
Old August 31st, 2008, 12:08 AM   #6
98 GT
14.60 @ 94.78mph
Thanks, I was planning on going with an alluminum block anyway, but that is the kind of information I am looking for, I'd like to know all the little odds and ends. Any known problems going with nitrous or boost on big bore motors, I would think the machining process would weaken certain things?
1998 GT
K&N: Intake
ram: clutch
BUCK OFAMA
Old August 31st, 2008, 12:17 AM   #7
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
the machining is high as well. the boss block is a a big bore block straight from frpp. the process is supposed to actually make the block more reliable. the thing about running boost on one of them is the compression, well thats if you have a pi swap done.
Old August 31st, 2008, 12:39 AM   #8
05mustang_TT_charged's Avatar
2005 Mustang GT
10.32@137.70
05mustang_TT_charged is a jewel in the rough05mustang_TT_charged is a jewel in the rough05mustang_TT_charged is a jewel in the rough05mustang_TT_charged is a jewel in the rough
here is a 4.6l based block from Ford that increases the displacement to 302 cubic inches using the stock rotating assembly....Ford Racing Performance Parts [M-6010-T50*] and ST Motorsports sells these block for almost half the price of Ford and ST Motorsports has built a few stroker based motors using this block and they were around 324-330 cubic inch modular stroker motors....contact this guy if you have any questions
350 rwhp and 310 rwtq at 6000 rpms through stock exhaust system
326 cubic inches of Twin Turbocharged hell will be running soon
Tuned by Wes @ TPS
LinkBack to this Thread: http://www.moddedmustangs.com/forums/96-98/86807-4-6-big-bore.html
4.6 big bore? This thread Refback August 31st, 2008 12:30 AM
Threads Similar to: 4.6 big bore?
Short stroker, large bore/ Long Stroke, small bore 331STANG 5.0 Mustangs 20 July 23rd, 2008 05:28 PM
bore gooberhead320 V6 Mustangs 5 May 11th, 2008 05:02 PM
bore Iownastang 5.0 Mustangs 11 February 5th, 2008 10:18 PM
Kenne bell big bore 2.1 00mustanggt 99-04 3 January 18th, 2008 04:09 PM
stock bore Stock 5.0 Mustangs 1 January 7th, 2007 12:56 AM
