275.6 HP PI Swap
i was at a tuning shop today and was talking with the owner. very smart guy, he told me that the 96-98 stang will do 195-210 stock but the last full PI swap he did with TB plenum and long tubes put 275.6 HP to the tires! he also said the opposite of everything i have learned. he claims almost all the gains come from the PI heads themselves and not the intake and cams? so now im debating on doing the Pi heads but i realy didnt want to spend the money. any ideas?
96 GT , cams,intake manifold,CAI,Exhaust,Full Hotchkis suspension, and many more |
48.47@ 12.58
he might mean 275 to the crank. that sounds right but rwhp with LT's and a tb and plenum? umm no. i had full exhaust cai tb and plenum back way when and i only put down 248/290
nope it was a 96 GT, he put 03 heads cams intake with a bbk tb and plenum, long tubes back and pulleys and he got that at the tires he said he was absolutely shocked. i saw the dyno print out. the guys realy knows his stuff hes got a few stangs that he owns and does about 2 a week but that was the only PI swap he did. any way my question is he claims if i dont do the heads its not worth it. he says almost all the gains come from the heads and that not to even bother if i dont do them???? everone else says the opposite but this guys knows cars like the back of his hand he dynos stangs all day ya know?
RLY SRS
If you had your NPI heads worked and some cams you would flow just as good as the PI swap...Actually better then the stock PI heads...
I would just have your heads you have on it now ported and polished and get some nice cams and call it a day...Of coarse the headers would be a big help too... |
Only to avoid advertisment , I will say I work for a company that works with cylinder head development for a particular racing series,, The P.I heads have a horrible short side radius making the nearly worthless N/A other than the compression bump, the combution camber design is also the same. I could see if we were talking on a F.I motor but not N/A. Raisng the compression with the NPI head to 10.4:1 will net higher results than the P.I at 10.4:1, just keep in mind flow numbers are not as important when your running a N/A motor it becomes more about efficiency.
2003 Cobra
So if you got the NPI heads ported you could get the same HP increase that adding PI heads will do? (40-60)
RLY SRS
Yes...If you had the NPI ported and polished and a new set of cams you would actually make more power then the PI Swap...
I would only have the P.I. heads worked if you plan to stay N/A, the same amount of work in a P.I head will net more if you plan to go forced induction down the road.
i have P.I. heads and i can tell you that its not gonna put you around that figure. sad but true
#11 | |
well its because of what i read and my experience with people putting them on cars. quick question what is with you being an asshole ?
#13 | |
The points I have made in this thread are proven and if you care to elaborate your knowledge lets take it to pm's and not muck up threads by incoherent web babble.
pm's it is
sent and resolved?
sounds good
it could happen mine was dynoed before the throttle body and upper intake, they told me that they and pullies was worth 10 rwhp so it could be but its got some things done thats for sure
97 gt with 2004 pi motor,acufab intake and 75 mm bbk cold air kit,bbk long tube headers, off road h pipe,2 chamber flow, 3:73, diablo chip with dyno tune 269rwhp 301rwtq 5.4 SOHC FOR SALE pm me for details |
Threads Similar to: 275.6 HP PI Swap
| Which one is easier??a rear end swap or engine swap? | Bies08 | V6 Mustangs | 42 | May 11th, 2010 04:33 PM |
| PI Head Swap and Transmission Swap | jEEd | 96-98 | 18 | May 14th, 2009 12:57 AM |
| Can't decide, engine swap or PI swap? A few questions... | k3vin | 96-98 | 24 | September 5th, 2007 06:48 PM |
| 3.8 swap to 5.0 | goldhorse | V6 Mustangs | 1 | August 10th, 2007 12:57 AM |
| 351 Swap | Cskit1500 | 5.0 Mustangs | 6 | November 16th, 2006 07:40 PM |
