Rev Problem
K guys i need some help. Ever since i put my trick flow upper plenum and 75 mm TB on when i rev the car up it takes a while for the rpms to come down. If your driving down the road and in lets say 3rd gear and let off the gas the car pulls back like normal but without touching the gas for like 5 seconds itll pull back even more like the rpms trying to finally come down more. Ive replaced the TP sensor, IAC, and also have a SCT tuner and had numorous tunes trying to fix it. Also my TB is closed as much as itll close without binding. Any other ideas on how i can fix this or whats causing the rpms to hang?
Mods in garage. http://www.moddedmustangs.com/forums...-member-11489/ |
i had the same problem. my problem was that i forgot to plug the wiring back in to the throttle positioning sensor so i'd check all the plugs around there
I triple checked everything is plugged in properly.
1997 Mustang GT
not as slow... PI swapped :-)
oh dang, i was lookin to install an aftermarket plenum and tb too, this interesting, i wonder if something like an egr restrictor plate would help?
If there's one thing in life you should never take for granted its the ability to drive fast when given the hp to. (PI engine swapped now, so i can go just a lil bit faster haha)oh yeah, and why the hell do imports always try to race me?! Last edited by mustangracer2g; September 23rd, 2008 at 03:13 AM. |
I fixed the problem, i made a IAC Plate and drilled a 17/64" hole for the IAC hole.
Rollin' 18/ pushin' 2
Perfect!!! I was about to recommend it.
1998 Mustang GT
i kinda have the same problem..how did u drill that hole on the IAC..on the upper intake plenum correct?
P.I. H/I,TF Stage 1 cams, Comp valve springs and retainers Steeda headers O/R X w/ SLP LM1 JLT CAI w/75mm TB and Plenum, Koni Adj. Steeda plates, lower control arms, rear strut brace,3:73, FRPP driveshaft, SCT tune, TF Underdrive Pulleys |
you can use gasket material and make your own gasket with a smaller diameter hole than stock to drop you rpm's faster.
Total cost is about $2.00 and you will have plenty of material left over for more.
Another method that i used that worked great is to buy a 1/2" copper pipe cap, drill a 17/64" hole in it, and put it in the hose coming outof your iac valve, worked wonders for me and alot easier then making a plate.
Very nice, i was thinking of getting one of those plates anyways.
![]() Cammed 2v Built By MustangMatt More mods than times your daughter has slept around |
What are you guys talking about drilling holes in? Does this mean get rid of you iac, put a plate over the hole and drill a hole in it? I'm kinda confused.
2003 Black Cobra. 2.3 whipple JLT RAI Dragon t/b 60s BAP Mafia Xcal3 MAC LTs w/ORX-pipe Borla stingers Billetflow IRS brace Eibach springs 1989 GT AFM b-31 cam crane springs 6.3 pushrods elec. W/P/fan 3:73s Manual steering tri-ax Shorties-orh-flows |
they're talking about making a new gasket to go between the iac valve and the tb with a smaller hole than the stock one.
1998 Mustang GT
i did that on my car..works pretty good...i used gasket material but it was kinda flimsy..imma re do it and actually use a metal plate and use the gasket to seal it...
Threads Similar to: Rev Problem
| Rev Limiter | gssjr11 | 96-98 | 14 | January 21st, 2008 02:49 PM |
| Rev Limiter | adam0421 | General Tech | 1 | October 21st, 2007 05:24 PM |
| Rev problem plz help | popmyclutch | V6 Mustangs | 12 | July 6th, 2007 11:18 AM |
| HELP!!! Annoying Rev Problem With 90 5.0 GT | Saleen351 | 5.0 Mustangs | 3 | April 20th, 2007 09:06 PM |
| where was Rev. Al then? | WAVEBYE | The Clubhouse | 40 | April 14th, 2007 12:00 AM |
