Need Advice
Old September 28th, 2008, 05:33 PM   #1
nHuman's Avatar
2003 Cobra
nHuman is on a distinguished road
Need Advice
Ok so after basically installing and completely new cooling system, I FINALLY got all the kinks out of it.
So I drive it around the block a few times to get it warmed up and then i pull in the driveway and pop the hood, the fan turns on and the temp gauge goes back to o on the normal and fan turns off im thinking YAYYYYYYY.
However i start to see a very lil touch of smoke behind the motor so i start trying to look around to see where it is coming from, but before i could look look enough to see anything the car acts like it starts wanting to cut off. So i run back to the cockpit to check gauge and its still reading cool, but i immed shut it off.
I took another 30min looking for anything dripping underneath or behind it. the ONLY thing i could find was where the heater core runs into the intake manifold out of the firewall, it has a small crack in the plastic part that comes up where the hose connects and some built up dried coolant there. I had to bypass the hoses to the heatcore on the firewall last year, (didnt have the money and wasn't really into the mechanic side of things back then). I figure i'll pull the hose off and clean the area and see if i can seal up the small crack for time being.
What was making the car want to stall out even tho the fan cooled the fluids back down?
Gonna be a beauitful day tommorrow i'd like to spend it workin on her.
Threads Similar to: Need Advice
Need Advice WAR-PARTY The Clubhouse 4 November 29th, 2007 03:08 PM
New '96 GT need some advice S10-92V8 96-98 13 October 31st, 2007 11:21 PM
07 GT...need some advice djslcfr 2005 - 2010 15 October 30th, 2007 10:58 PM
I need advice toronto_stang 5.0 Mustangs 8 May 25th, 2007 05:49 PM
Advice and HP Help fordboy4rd 5.0 Mustangs 14 March 10th, 2007 01:32 AM
