New here with a couple of questions... - Page 2
LinkBack (1) Thread Tools
Old October 8th, 2008, 08:42 PM   #21
hotrod lincoln is on a distinguished road
if you take the wheel off make sure you take the pos cable off of the batt for a few mins to let the SRS system discharge then unplug the yellow covered wire with the yellow plug at the bottom of the column that is your air bag wireing. then be very carfull when removing it always set it out in the open and face up away from anyone so if it does happen to go off no one gets hurt. if you set it face down if it goes off it will shoot 100+ feet up in the air and it WILL hurt when it comes back down.
Old October 8th, 2008, 08:56 PM   #22
brandt's Avatar
1998 Mustang Convertible
brandt is on a distinguished road
Send a message via AIM to brandt Send a message via Yahoo to brandt
I appreciate the heads up (no pun intended)... but from most people responses it would be foolish for me to try... as much as I would love to have a nicer looking wheel (2005 type) or even settle for the same wheel but in black, I really think with my lack of skills I would somehow screw it up and go from having a fully functional boring wheel to an awesome one that is in the garage just looking pretty... and no wheel to drive with...
and since every shop i have contacted will not switch out a wheel I think I need to just figure out something less crucial to screw up...
thanks
B
Old October 8th, 2008, 10:47 PM   #23
1996 Mustang GT Vert
Blower Head is on a distinguished road
Originally Posted by brandt View Post
cool... that was actually what i was thinking... esp if i can switch out the door inserts and then the console, that way the black coming down from the top of the dash into the middle ac/radio area continuing into the console would really look cool... no issues with the convertible switch or the extra power plug on the bin area?
thanks
B
The console I got even came out of a convertible, but that does not matter as the non-convertible has a pop in coin holder that goes into the switch opening. The extra power plug reqiured that you use the bin inside the console that is correct for that type. The one I got did not come with it so a trip to the junk yard yielded me the correct one (I just hunted around and found the correct one out of a newer mustang).
96 GT vert, Aftercooled Vortech, Lightning MAF,42# injectors, saleen cams, Bullitt intake, tune by Hitech, Magnaflow catback and O/R xpipe, Cobra brake upgrade, lowered bilstein suspension w/MM c/c plates and subframe connectors 3000 stall and 3.73's
Old October 9th, 2008, 08:01 AM   #24
Baby96's Avatar
Baby96 is on a distinguished road
Maybe you can try one of those leather steeringwheel covers..I bought one a few years ago..still looks great.
If you change your mind later on, you can always remove it.
Old October 13th, 2008, 03:19 PM   #25
brandt's Avatar
Well I did end up getting a black steering wheel cover... it looks good enough... now i think once i can find some black door inserts and a black center console it will really look good... now somehow i still need to figure out what to get for headlights...
B
Old October 13th, 2008, 06:25 PM   #26
97GT4.6's Avatar
97 GT
14.2@99.8 @ 4800 ft
97GT4.6 has a spectacular aura about97GT4.6 has a spectacular aura about97GT4.6 has a spectacular aura about
Send a message via AIM to 97GT4.6
Get some crystal clear lights, or get them smoked, that looks really cool.
Cammed 2v
Built By MustangMatt
More mods than times your daughter has slept around
LinkBack to this Thread: http://www.moddedmustangs.com/forums/96-98/91010-new-here-couple-questions.html
New here with a couple of questions... This thread Refback October 1st, 2008 08:10 PM
Threads Similar to: New here with a couple of questions...
couple questions.. GOTTORQ 2005 - 2010 5 June 27th, 2008 12:20 AM
couple of questions Steve O 99-04 35 January 15th, 2008 12:38 PM
Couple of questions silver99gt 99-04 2 November 19th, 2007 08:37 PM
couple questions MisterFast3 V6 Mustangs 23 September 18th, 2007 09:55 PM
i have a couple questions rx1_ns 96-98 25 July 10th, 2007 05:25 PM
