Just looking...
![]() iTrader: 1 reviews
Valve Knock
I was passing a tractor yesterday and as i was doing that i started to hear a knocking noise. So i drove home and can clearly tell that there is a knock under the right valve cover. We will probly pull the valve cover next week to check it, as of right now i am still driving the car because its my DD. It does not smoke anything. I am thinking its either the cam is damaged or a valve is bent. IF the cam is just dammaged and needs to replaced, would it be worth swapping in a PI cams even if i dont have any other PI stuff, or would the cams alone not make enough extra hp to even be worth it. If it is the valve train and the head needs to be pulled, how much extra effort would it be to put on PI heads? they should be direct bolt on correct? THe car has 121,000. THanks.
![]() iTrader: 2 reviews
yes pi swap is direct bolt on. i believe the pi cams will work on the npi heads
2002 mustang v6- Auto, K&N CAI, Flowmaster dual exhaust, Black bullits dd 1996 mustang gt- 5spd, black, cobra hood, stock November Birthday Club Founder Old username: 97gt www.discounttiredirect.com |
Hey I have the same problem! But I have XE270AH Comp Cams, intake manifold, PI Windsor heads, etc. all lying around haha. I've just been too lazy to get to them. Guess I have a reason to do that now!
The Hammer
Millenium Falcon
the cams are worth about 10rwhp without the intake. It's worth it if u need to pull one side apart anyway.
Cost me under $200 including parts and lube when i swapped mine |
Just looking...
When you say this, what does that mean? $200 to just do cams? Or is that intake too?
1997 Mustang Cobra
8.65@84mph
thats just a cam. might as well throw on some PI heads and make the power
Threads Similar to: Valve Knock
| knock? | mystang0673 | 99-04 | 2 | August 25th, 2008 12:00 AM |
| Egr Valve And Pcv Valve Delete? | Jeffery9508 | V6 Mustangs | 16 | January 28th, 2008 09:45 PM |
| knock knock | 93fourbangerstanger | 2.3 Mustangs | 2 | August 23rd, 2007 12:09 AM |
| Knock Knock | MSTGGT00 | 99-04 | 3 | May 31st, 2007 01:14 PM |
| Knock Sensors? How Many on a V8? | Brasure | New Members Introductions | 2 | December 19th, 2006 03:41 PM |
