oil on top of driverside valve cover
Old October 3rd, 2008, 09:58 PM   #1
1998 mustang GT
ron98gt is on a distinguished road
Cool
ok i recently changed my 6lb pully to 11lbs, not sure if this has anything to do w/my problem. so the other day i got on the pedal pretty hard and herd a high-piched whine(i was sure that it was the supercharger), so i desided to look under the hood when i got home. i found a small amount of oil on top of 1 of the valve covers on the 2nd bolt indent from the back(fire wall). so i was just wondering if this could be caused from the added boost or am i over analizing the need for a new valve cover gasket. what do you think?
98 gt blk on blk 90k miles with BBk 75mm throttle body, C&L plenum, Diablosport predator,powerdyne supercharger & a few other things.
Old October 3rd, 2008, 11:15 PM   #2
Proud American
MustangMatt96GT's Avatar
sounds like it could be blow by from the added boost. Do you have a catch can?
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
25.3 SFI Chassis Build
Never Lift Racecars
Old October 3rd, 2008, 11:43 PM   #3
1998 mustang GT
Cool
no, to be honest i have never heard of it. what does it do and where does it go?
i tried to see where the oil is comming from but i see no trace anywhere except near the bolt on the valve cover where the oil is. i was thinking that either the bolt is loose or i need a new gasket. the 1 thing that i dont understand is, is there that much pressure under the valve cover that it would leak at the top of the cover?
Old October 3rd, 2008, 11:44 PM   #4
Proud American
PVC blow by, and im not good to tell you how it works and what not. But i know ChrisJ and a few have some of them.
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old October 4th, 2008, 02:38 AM   #5
1998 mustang GT
i thought the same thing but i see no evidence of it.
Threads Similar to: oil on top of driverside valve cover
Valve Cover !!!!! REIGNYC 5.0 Mustangs 1 July 26th, 2008 08:15 PM
No oil in valve cover? TrAb 5.0 Mustangs 18 May 11th, 2008 10:12 PM
Valve cover ? 88mysticgt 5.0 Mustangs 3 April 5th, 2008 10:00 AM
Valve Cover mustang1072 V6 Mustangs 15 March 23rd, 2008 09:30 PM
convertible top cover RichM V6 Mustangs 3 April 24th, 2007 12:00 PM
