Not getting gas to the engine or something
Old October 6th, 2008, 06:40 PM   #1
ndfrspd's Avatar
1998 Mustang GT
1:34.43@13.86
ndfrspd is infamous around these parts
So I bought some MIL eliminators from american muscle and put them in my car, with the battery connected. Then once they were plugged in, i realized i had to disconnect the negative terminal on the battery to reset the computer in the car. so i left it off for a while while i reinstalled my front bumper and then plugged the negative terminal back on the battery and went to fire up the car. I push in the clutch turn the key and it fires and runs for about 7 seconds then i get out of the car to close the hood and it slowly starts to die then it dies. It seems to me that the fuel stopped getting to the engine and thats what caused it to crap out. Also i noticed now that my battery light turns on when i try and start the car, although my battery isnt terribly low. So all of that was with my MIL eliminators installed. Now, I took the mil eliminators out thinking it had something to do with it and my car will start after about an hour of waiting but it will only start for about 1 second, then die. And if i try it again it wont start at all.
I am most likely sure its the fuel pump because when my car was inspected last, the mechanic said the fuel pump was about to go soon and it was just pumping the minimum amount of fuel needed.
Can someone point me in the right direction here? What are your first thoughts?
"The only way to learn about a car truly is to break something and fix it yourself..."
Old October 6th, 2008, 11:11 PM   #2
1996 mustang gt
gtdan is on a distinguished road
Send a message via Yahoo to gtdan
i would check the plug wires and coilpacks ! does your fuel pump humm when you turn your iggnition on without starting the car?
sold the stang
Old October 7th, 2008, 03:02 PM   #3
ndfrspd's Avatar
1998 Mustang GT
1:34.43@13.86
no, i got no humming noise when i turn the key... but i found a deal on a pump so im gonna go get it. also it might sound stupid but the car has almost no gas in it, the gas gauge says empty, and with a crappy pump is it possible it just has not enough gas? ill try 2 gallons of premium today, and if it still dont work, ill put in a new fuel pump
Old October 7th, 2008, 03:32 PM   #4
ndfrspd's Avatar
1998 Mustang GT
1:34.43@13.86
NEVERMIND... when i turn the key to accessory and dont crank the engine i hear a humming noise from what sounds like the rear of the car for about 1 1/2 seconds. what does this mean?
Old October 7th, 2008, 04:21 PM   #5
Proud American
MustangMatt96GT's Avatar
means your fuel pump is pumping, means the Iteria swicth is good in back too...
Next to look is to see if you are getting pressure at the fuel rail by hitting the schrader valve(tire valve thing). And if so then you have a MAF sensor problem of a spark problem.
And put a few gallons of gas in it. That could be your problem
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
25.3 SFI Chassis Build
Never Lift Racecars
Old October 7th, 2008, 06:01 PM   #6
ndfrspd's Avatar
1998 Mustang GT
1:34.43@13.86
yea man i just put 2 gallons in and it started right up... piece 'o shit gas gauge. thanks guys.
Old October 7th, 2008, 06:38 PM   #7
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
Dude, your'e a trip!!!
Your posts always make me laugh.
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Threads Similar to: Not getting gas to the engine or something
With gas prices this way ive decided to get a gas saver...Should I trade the stang? Drick The Clubhouse 18 September 2nd, 2010 03:26 PM
2007 Pump Gas Drags 32 of the fastest pump gas cars Mellon Videos 7 June 14th, 2008 12:08 PM
Washed n cleaned engine today.. pics of engine bay. MustanG_guy17 The Clubhouse 40 January 4th, 2008 10:14 PM
Check engine light comes on when stepping on gas MonsterSD 5.0 Mustangs 2 June 15th, 2007 05:43 PM
