LinkBack (1) | Thread Tools |
#1
1987 mustang gt
dont know yet
lincoln motor in a mustang
I need some info im thinking of buying 1998 mustang gt with a bad motor i can get a 1998 lincoln motor for it what will i need to make it work in the mustang? motor ecu and wireing??
Proud American
is the lincoln motor a 2V? If so its a derect drop replacement. YOu might have to swap oil pans, i know i did.
But i have a 95 crown vic motor in my car now. wiring and harness works the same, you will have to use a NPI or PI mustang intake though
#3 | |
1987 mustang gt
dont know yet
thanks for the fast reply so the harness will just plug in ? |
1987 mustang gt
dont know yet
wait what am i thinking its a 4v its a mark 8 motor
97 Cobra
Lincolns started using the teksid 4valves in 93.
They have much less aggressive cams, a worse intake, and non forged bottom end if I remember correctly. Still its a teksid 4valve with B heads..... STILL better than the GT 2valves in my opinion. |
yes i have a 94 mark VIII and its just about the same motor but it has a 6 bolt crank vs the cobra 8 bolt. the exhaust cams are not as hot as the cobras are but the intake cams are the same. mark intake is better for low end torque then the cobras are due to the longer thinner runners. i know the marks do not have a forged bottom end but i did not know the cobras did either until the 03-04 blown cobras.
#7 | |
97 Cobra
03 was the first year for forged rods/pistons. The went back to iron blocks though so you're better off forging a 96-98 Teksid. I believe they still use IRMCs too. As for the harness I think you will need a cobra computer to control the IMRCs and Knock Sensors since the GT had neither. I've heard of people using window switches or aftermarket ECUs to manage the IMRCs if you must keep them, many just force them open and leave it. Hopefully I've covered enough to help out. |
1987 mustang gt
dont know yet
well all i need to do now is get every thing to my place and start wrenching thanks guy
97 Cobra
The Hammer
Millenium Falcon
no lincoln motor had a forged bottom end, and the only 4v's that had one are the 03+ cobra and the crankshaft of the mach 1's
#11 | |
97 Cobra
In fact the Mach1s had forged cranks but only in the 5spd. The Autos had the same cast GT crank. All the cobras from 96 up have had the forged crank from germany. Perhaps you're confusing the forged internals of the 03/04 with the forged crank? Before 03 they had the forged crank, but hypereutectic pistons. |
#12 | |
Proud American
#13 | |
The Hammer
Millenium Falcon
I'm not confusing anything i was pointing out no lincoln had a forged bottom end, and that the 4v's didn't start getting them until 03. the post that i quoted implied that u could get a 4v with a forged bottom end like it was a christmas tree in december |
#14 | |
97 Cobra
I replied to the first post since it sounded like you meant all Machs were forged and I thought you meant the lincoln motor WAS forged. I just read it as if you were replying to me saying "No, the lincoln motor was forged." with the no redacting what I said. Of course you didnt mean that and I just read it that way. |
alot of guys on the lincoln forums that run stall converters in there cars just take out the IMRC butterflys and epoxy the holes where the shafts go and call it done. also if you can find the imrc plates from a 98 only cobra they are plastic so they help to keep the intake cooler for a somewhat cooler intake charge. kinda the same idea as a wood or plastic carb spacer.
#16 | |
1987 mustang gt
dont know yet
so i can just leave the irmc open and use my ecu? what about the knock sensors? what do i need to do not to run into major problums |
#17 | |
97 Cobra
You should be fine. If you're worried get a cobra computer. |
1987 mustang gt
dont know yet
thanks guys ill keep yous posted on the build
LinkBack to this Thread: http://www.moddedmustangs.com/forums/96-98/92228-lincoln-motor-mustang.html
| lincoln motor in a mustang | This thread | Refback | October 10th, 2008 01:14 PM | |
Threads Similar to: lincoln motor in a mustang
| Lincoln LS 4V motor? | Schraders | 99-04 | 21 | March 24th, 2008 11:21 PM |
| Difference between 98 cobra and Lincoln Mark VIII mod motor? | noyz25 | Modular Mustangs | 35 | October 18th, 2007 06:42 PM |
| mustang 5.0 and lincoln 5.0 engines | boyle07 | 5.0 Mustangs | 1 | February 19th, 2007 10:02 PM |
