second set of LCA bushings toast...what now?
It’s a 98 GT 5 speed that I bought already equipped with Maximum Motorsports lower control arms. At about a year the right side poly bushing came apart so I replaced them. When I was talking to the guy at Maximum about ordering the new bushings he said "it was the right one wasn't it?" And told me the bushings would go again and suggested I go with their solid ended or "Extreme" control arms. Well he was right...the right side bushing is shot again after a year. Since I refuse to change my driving style
Is my only way around this problem to get the LCA's with two solid ends?
SVTfocus, F250
what about a solid bushing instead of poly?
rather then new control arms |
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
+1 you can get spherical bushings that will go in its place. i had some trouble with a control arm doing the same, i ended up with billet bushings.
I didn’t even think about something like that...I did a couple of google searches and found a lot of Upper spherical replacement bushings (Steeda has some for about $100) but nothing specifically listed as a LCA replacements...are they interchangeable? If the upper bushings won’t work on lowers does anyone know of a source for some spherical lowers?
mm's nitrous mod
2000 mustang gt
there are just lower spherical lowers, i cant remember who all offer them off the shelf. i will have to do a little looking to see if i can find them. the upper and lowers are different and will require different bushings/bushings.
2001 svt cobra
12.84@110
crazy i have this same problem thought it was just my axle housing or something i made some bushings at work out of some hard nylon but after awhile they split as well guess i will have to do some research as well. have the upper sperical ones but cant find lower control arm bushings
![]() tri-ax, alum. drive shaft,caster/camber plates,cia, SCT chip,4.10 gears,solid axle swap, 31 spline axles,UPR control arms, UPR A-arms, flowmasters,MSD 2-step,SLP line lock,front and rear coil overs 307rwhp,309rwtq MM New Edge Cobra Club Member #4 |
mm's nitrous mod
2000 mustang gt
you could always try delrin bushings.
I've googled for these alot now and i still can't find a source. If spherical replacement bushings to fit our lower control arms or my Maximum Motorsports LCA exist...please someone tell me where you got them.
2001 svt cobra
12.84@110
XD Rear Lower Control Arms, 1999-04, with perch, swaybar
[click for larger image] $339.95 Part #: MMRLCA-31 Manufacturer: Maximum Motorsports Note: Actual product may differ from photo. Add: Extreme Duty Rear Lower Control Arms, with Spring Perch and Swaybar Mount, 1999-04 this is the only thing i could find
Smitty there are also others that make LCA's with spherical bushings at both ends...if thats what your looking for. In my case, when i started this thread, i thought my only option was to replace my current LCA's with some of those control arms. Until a couple of posters suggested just getting replacement spherical bushings...my problem is finding those replacement sphericals.
Side note...when i bought my last set of bushings from Maximum Mtorsports they did offer me their upgrade deal...i could trade in their Heavy Duty LCA's for the Extreme Duty LCA's and get a discount. But since they were already on the car when i bought it and i wasn't the "original" purchaser i couldn't take advantage. I then asked if i could buy just the bushings from the "Extreme Duty" LCA's...He said something like...they were an integral part of the control arm so no i couldn't. Last edited by markush; October 15th, 2008 at 11:58 PM. |
2001 svt cobra
12.84@110
i see i was looking for replacements as well but couldnt find anything from anyone. if you ever find anything let me know i would also like to upgrade.
Threads Similar to: second set of LCA bushings toast...what now?
| Engine Toast!!! | Stangostrone | 99-04 | 11 | July 27th, 2008 04:23 AM |
| CA Bushings | 99cobradroptop | 99-04 | 6 | July 23rd, 2008 02:50 PM |
| fuel gauge toast??? | hlinar | 96-98 | 2 | July 11th, 2008 10:08 PM |
| Is this toast or not | hooligan | 2.3 Mustangs | 4 | April 16th, 2008 02:59 PM |
| bushings | superbeef1000 | 99-04 | 4 | August 12th, 2007 06:27 PM |
