Best overall cams for a nPI head
So i decided that i don't want to put on PI heads, i don't want to raise the compression ratio much with the high mileage my car has, so im going to keep the stock nPI heads on my car. What are the best cams that I can run with my heads?
Im considering getting PI cams, but not sure if its worth the work for the amount of power. Is there anything thats not too expensive that will give me more gains then stock PI cams without too much work? Thanks
![]() Cammed 2v Built By MustangMatt More mods than times your daughter has slept around |
PI cams ftw man... i'd grab them... seriously..i found mine on ebay for 45 bucks shipped...few hours work..plus you have PI intake.. 45 bucks plus 15hp...not bad man...
1997 Mustang GT
not as slow... PI swapped :-)
yeah, ive looked for cams for my non pi and they all cost like 40-500, so for as cheap as PI cams are, i might consider pickin up a set too for the easy hp, and if they're degreed right its even better
If there's one thing in life you should never take for granted its the ability to drive fast when given the hp to. (PI engine swapped now, so i can go just a lil bit faster haha)oh yeah, and why the hell do imports always try to race me?! |
yeah, i think thats what im going to do.. easiest and cheapest way to get some power. Does comp cams make anything thats good that fits a npi head?
crower makes NPi cams im pretty sure. why dont you talk to your buddy matt about this. im sure he could give you a better answer. but i still say PI cams. very cheap and very easy for the gains you get.
The Hammer
Millenium Falcon
put in PI cams and have matt degree them for u... then get a nasty tune
25-30rwhp |
1997 Mustang GT
that does sound pretty mean haha this is def the route im gonna go, with a pi intake ftw!
PI cams and intake are a great gain over the NPI stuff.
I'm rocking NPI heads still too, fully ported and crower stage 2 npi blower cams, and Livernois PI intake. If you do go with aftermarket cams, stage 2 will require valve springs too. S trim/methanol, on 14psi, I made 515rwhp/475rwtq. NPI's have the same potential once they're worked as ported PI's. Just added an 8 rib, and 7.5" crank, it makes 17-18psi now. Joe at Trick tuners and I are dialing it in now, and hopefully will put out 600rwhp or close. |
#9 | |
1997 mustang gt vert
Do you have to change the timing or gears for the cams when changing them?
Anyone need pi cams let me know i have a fee sets pm me
MM FOBRA CLUB MEMBER #1 |
1997 Pacific Green Cobra
14.80 No traction
no you dont. They bolt right in straight up
GT ENGINE (temporary) 4.30 Gears , 31 spline Moser axles , Detroit tru Trac diff, Jmod 4r70w , Pi intake Hitech stage 2 cam, Vortech V2 3.33 pulley. Alum drive shaft. Lowering kit x2 ball joints ,screamin demon coils, LCA " |
Threads Similar to: Best overall cams for a nPI head
| PI cams and Intake with NPI heads | KIKa55GT | 96-98 | 28 | January 19th, 2008 03:52 PM |
| PI Cams and NPI followers | 97redgt | 96-98 | 4 | August 29th, 2007 05:01 PM |
| crower NPI cams | Monster stang 97 | 96-98 | 24 | May 23rd, 2007 06:04 PM |
| PI cams on NPI heads valve set up | ujslost | 96-98 | 1 | March 29th, 2007 01:41 AM |
