The most important tips when installing a new intake manifold
Old October 19th, 2008, 03:52 PM   #1
ndfrspd's Avatar
1998 Mustang GT
1:34.43@13.86
ndfrspd is infamous around these parts
Exclamation
I just bought a new intake manifold. Its a stock replacement with aluminum crossover. I have a haynes repair manual and I read the guide in the sticky for swapping manifolds, but can anyone offer tips or important things they learned from first hand experience, so i dont have to learn the hard way.
"The only way to learn about a car truly is to break something and fix it yourself..."
Old October 19th, 2008, 06:15 PM   #2
MikeD05GT's Avatar
2005 Mustang GT
MikeD05GT will become famous soon enoughMikeD05GT will become famous soon enough
Send a message via AIM to MikeD05GT
its very straight forward. make sure you get the tool to disconnect the fuel lines. other than that, the manual will help a ton... good luck
Old October 19th, 2008, 06:26 PM   #3
texas96gt's Avatar
n/a
texas96gt is on a distinguished road
I just did mine last weekend. Make sure that you remember where your manifold bolts go. I made the mistake of putting the wrong bolt in the hole closest to the firewall. When I put my antifreeze back in, it leaked out the back of the manifold. Come to find out I put the bolt that goes by the coolant crossover in the last hole on the driver's side. That bolt is slightly longer than the other manifold bolts so it did not tighten the manifold down all the way. So I swapped them and the leak stopped. Also it is a good idea to get new fuel injector O-rings. You will need a total of 16 one for the top and one for the bottom. Good luck!
Threads Similar to: The most important tips when installing a new intake manifold
Swapping a 98 V6 intake manifold with for a 99 V6 manifold 98mustang V6 Mustangs 6 November 20th, 2010 11:20 PM
Installing Exhaust Tips whitehorse01 99-04 3 June 20th, 2008 08:06 AM
Help Installing New Intake mikeGTmurr46 99-04 9 December 21st, 2007 08:02 PM
Help With Installing New Intake mikeGTmurr46 Modular Mustangs 0 December 17th, 2007 11:14 PM
installing intake manifold ayyubam2002 General Tech 2 July 20th, 2006 10:13 AM
