Lots of PI swap questions
Old October 20th, 2008, 09:03 PM   #1
2000Mustang's Avatar
1998 Mustang GT
2000Mustang is on a distinguished road
So, im getting serious about my PI swap, and I have some questions: I plan on using Ford Racing heads, would the gains be worth it to pay $799.95 for a Trick Flow Track Heat intake manifold as opposed to $219.95 for a stock replacement intake? Also, what would be better, 70mm or 75mm throttle body on a PI swap, bolt-on '98 GT? And when i buy the throttle body do i need to buy the plenum to assist? Would it be worth it to P&P the stock heads if I can scrape the money? I do not plan on adding cams (at least not right now), is it even worth it?
Off-road X pipe, Magnaflow mufflers, BBK cai, 3.73 gears, ZEX 75 shot (not hooked up), 17in. Bullitts, lowered
Old October 20th, 2008, 10:43 PM   #2
1998 Mustang GT
burlingtonNC98GT is on a distinguished road
keep the stock npi heads and port and polish them and throw some nice cams in them. and yes it is definitely worth it. go with the 70mm throttle body unless u plan on boosting the engine any time soon, in which case i would recommend the 75. go ahead and by the plenum. accufab is the best brand for both tb and plenum. as for the intake, im not too familiar with the trick flow model u are referring to so i cant really hellp u out there but i cant imagine it being that much of an improvement over a standard pi intake.
1998 GT
PI intake
PI cams
bbk cai
flowmaster 40's catback
bbk x-pipe w/ cats
march pulleys
RAM clutch
Steeda Tri-axe
Old October 21st, 2008, 11:16 AM   #3
'97'Cobra's Avatar
1997 Mustang Cobra
8.65@84mph
'97'Cobra has a spectacular aura about'97'Cobra has a spectacular aura about'97'Cobra has a spectacular aura about
he said it best man P&P and throw in a new cam. I would go ahead and by the trickflow since your going to get a intake anyways.
i usually wave first, but if the guy is sexy and i'm drunk, i might lift up my shirt and flash him as well.
MM Cobra Club Member #61
Old October 21st, 2008, 06:43 PM   #4
BlueStangGT's Avatar
BlueStangGT is on a distinguished road
My experience with the PI headswap was awesome. It's so much cheaper to do it now than it was in 2001 when mine was done that I can't think of a good reason why not to use PI heads. If you've got time on your side and are patient I'm sure you can find a set of PI heads at a bargain. Otherwise I think the comments here are sound. I would also recommend getting subframe connectors before you get much farther with the power, you'll be amazed at how much better your car behaves.
1998 Bright Atlantic Blue GT Coupe - 5 Spd., Big Bore Headswap, 4.30's, blah, blah, blah...
Old October 21st, 2008, 07:34 PM   #5
johnr2001's Avatar
2001 GT
johnr2001 is on a distinguished road
just do it right and get the heads and cams. I picked up a set of 04 heads and cams for my sons 98 with 21000 miles on them for 200.00. there are plenty of deals out there just shop around
03 Mach 1 full eaton swap, 18" chrome bullitts, H&R springs, 5.0 shifter, slp2, mac catted H, FRP 4.10's,
443 RWHP/ 386 TQ
Old October 21st, 2008, 08:45 PM   #6
1998 Mustang GT
there is nothing wrong with keepeing th npi heads. u dont gain enough hp from pi heads to justify the cost. plus u have the dificulty of having to deal with extra compression which isnt too good if u ever plan on boosting that engine. just save the cost of the new heads and use it to port and polish the npi heads and buy some really nice cams for them and ur set
1998 GT
PI intake
PI cams
bbk cai
bbk x-pipe w/ cats
march pulleys
RAM clutch
Steeda Tri-axe
Old October 21st, 2008, 09:31 PM   #7
1998 Mustang GT
Ok, honestly im liking P&P the stock heads and nice cam. More realistic build for my situation. Now can someone direct me to 'really nice cams'?
Threads Similar to: Lots of PI swap questions
pi swap questions zigbigadoru 96-98 5 July 11th, 2008 10:28 PM
lots of paint questions johnbarberr Visual 6 September 5th, 2007 06:54 PM
Can't decide, engine swap or PI swap? A few questions... k3vin 96-98 24 September 5th, 2007 06:48 PM
Lots Of Questions! Please Help! DB67 Classic Mustangs 2 October 13th, 2006 11:20 PM
