Need real answers for 98 GT fuel pump replacement
I've searched and asked several individuals about which fuel pump to use on my 98 GT. Some say use the 255 Walbro "works fine" and some say it'll burn up in a year. I'm thinking there are no real fuel upgrades besides replacing the entire tank and going with an "Aeromotive, BG" set up. I already have a 255 inline Walbro. This would be extremely expensive. I'm ready to give up and order the OEM pump.
11.47@120.58
Walbro is fine, only burnout problems they have is when their used (inappropriately) on 99+ returnless system.
I have an intank 255lph Walbro in my 1995 Mustang to support my supercharger habit.
2003 Mustang Mach1 1995 Thunderbird LX 4.6L; 1995 Mustang 4.2L; Eaton MPX Supercharger, 11.61 @ 118mph |
I forgot to mention that the burnout is due to the '98 style fuel pumps being voltage regulated. I've been told that '98 is a year all in itself.
11.47@120.58
No it's 99+ that is regulated by variable voltage. In a return style fuel system (pre 1999 Mustangs) the fuel pressure is regulated on the fuel rail in the engine compartment. The fuel pressure regulator acts like a faucet allowing fuel to go back to the fuel tank to relieve pressure. In 1999 Ford went with a returnless system, meaning there are no lines back to the gas tank and no fuel pressure regulator per se. Instead, the ECU increases and decreases the voltage to the fuel pump to regulate fuel pressure. If the fuel pump isn't designed for this (example: Walbro is designed to operate at a constant 12v) then it can burn up.
Your 1998 has a return style system, meaning a Walboro will operate as intended in your Mustang. |
Ford Motorsports offers a 190lph pump specifically for the 98.
Look Ma! My First Post!
Hey Randy
Wow its a small world. I was looking for a larger pump for a 98 and found your post. Do you have a part number for the ford part? I found a vortech 255 pump (8F001-265) that they said is an exact fit. We will see...... I have been working on this problem for a week now. If you have the ford number I will have it for back-up if the vortech pump does not work. Is that the pump in your saleen?? Thanks Chris
www.alliesautomotive.com PS pick up the latest copy of Modified Mustangs. Michele's car has a 7 page spread. |
Did you guys figure out the answer to this situation? I have a 98GT and need a bigger fuel pump! Help.....
Rollin' 18/ pushin' 2
Holy old post Batman!!!
Seriously though, a walbro will work fine in a 98.
Threads Similar to: Need real answers for 98 GT fuel pump replacement
| Need a Few Answers On Engine Replacement | OcOnnor220 | 99-04 | 2 | September 4th, 2007 06:16 PM |
| Fuel pump | kwill5 | 96-98 | 1 | August 19th, 2007 07:18 PM |
| Water Pump Replacement | Snipe061 | V6 Mustangs | 3 | June 1st, 2007 05:11 PM |
| fuel pump fuel pressure stuff | JBIGBOOTSY | 5.0 Mustangs | 2 | April 26th, 2007 03:31 PM |
| Fuel Tank Replacement | oltimer | 94-95 | 9 | January 24th, 2007 07:40 PM |
