Advice on Pi swap (in the middle of one)
Old November 17th, 2008, 06:06 PM   #1
Doggins's Avatar
Doggins is on a distinguished road
Aright I'm in the down and dirty of my PI swap. Got all the accesories off, timing chain cover is off, and im stuck.
I cant get the @#!@#!@ Exhaust Manifolds disconnected from the exhaust!
Any tips? Most of the reason is I dont have a lift only jackstands and I dont have an impact wrench just a breaker bar. Anyone got some advice on how to get them off. It's the only thing keeping the heads on the engine.
Thanks!
Old November 17th, 2008, 06:16 PM   #2
330CubeGt's Avatar
1994 Mustang 5.0
1996 Mustang V6
330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light
iTrader: 14 reviews
Good job now you got your computer dirty.
To be honest your best bet would be a breaker bar and some PB-blaster/
WD-40/Liquid Wrench etc.
I tried a buddies car with a impact and they did not budge but i was able to get them to break loose with a breaker bar After a sprayed it down with some PB-blaster a few times.
-04 IRS - Magnaflow - Wheel Replica - Autometer - FTBR - FRPP - SCT - Brembo - PRO 5.0 - BOI-
Old November 17th, 2008, 06:41 PM   #3
The Doctor
Lefty's Avatar
'01 Cobra Vert.
iTrader: 11 reviews
This freeze away shit. Saw it on horsepower tv. It's in like a can and you spray it on for a couple of seconds then let it sit for a couple more. Then try it. I don't know what the product is called though. You should possibly look into it...
Old November 17th, 2008, 06:48 PM   #4
330CubeGt's Avatar
1994 Mustang 5.0
1996 Mustang V6
iTrader: 14 reviews
Now that you say that i have used Dust off Up Side Down To Freeze Things .It Kinda works.
Old November 17th, 2008, 06:48 PM   #5
NMR-2vGT's Avatar
1996 GT
Too Slow....
NMR-2vGT will become famous soon enough
Send a message via AIM to NMR-2vGT Send a message via MSN to NMR-2vGT
Just go with the PB blaster and breaker bar, they should break loose eventually.
1996 Mustang GT, Full PI Swap, MGW Shifter, Magnaflow Cat-back, K&N Filter
MM Unite For Bubba
Old November 17th, 2008, 06:56 PM   #6
BAzombie's Avatar
1996 GT Convertible
13.88@100.71
BAzombie will become famous soon enough
good one.
I'm a newbie so this might sound dumb, but can't you just unbolt the manifold from the head ?
You also never mentioned if you can heat them, so I'll guess no on that.
In that case your best bet it a breaker bar and some type of penetrating oil which was already stated.
You can try putting a pipe or the boxed end of a big wrench on the end of the bb for more leverage.
You can try turning the bb with your legs instead of your arms for more power.
Worst case scenario is the studs snap, but with the heads coming off you can just bring the manifolds to a shop and have new studs put in.
I'll be going through the same thing sometime over the winter, but I'm putting long tubes in while I have the top half of the motor off.
Good luck with the bolts. Only thing I hate more than manifold bolts are brake line fittings.
Mods: Katzkin Leather, MMR stage II heads w/PI cams, PI intake, Accufab 75mm TB & Plenum, CAI, Ram HDX clutch, Pacesetter LT's & X pipe, Pypes hi-flo cats, Flowmaster cat back,3.73 gears, Sct SF3 tuner, Mamba M2's
Old November 17th, 2008, 09:13 PM   #7
Doggins's Avatar
aright cool, I put some PB blaster on it and ill let it it overnight. I'm still having a problem getting to the passenger side bolts, the cross-member is in the way. Any hints? Other than removing it...
Old November 17th, 2008, 09:23 PM   #8
NMR-2vGT's Avatar
1996 GT
Too Slow....
You have to use a swivel and an extension or 2
MM Unite For Bubba
Old November 17th, 2008, 10:35 PM   #9
The Doctor
Lefty's Avatar
'01 Cobra Vert.
iTrader: 11 reviews
Threads Similar to: Advice on Pi swap (in the middle of one)
In the middle.. Genevieve! The Clubhouse 42 May 14th, 2008 01:08 AM
Help, in the middle of PI cams/intake swap sa96vertgt 96-98 6 July 16th, 2007 09:44 AM
bout to do a 351 swap any advice kratos2250 5.0 Mustangs 13 June 21st, 2007 02:14 AM
middle consoles droppedbass87 Visual 2 May 10th, 2007 11:22 AM
engine swap? i need some advice cobrakid 5.0 Mustangs 7 January 17th, 2007 08:52 PM
