still needing help!!!
okay guys, my problem is, that my car, even after it is warm, and i have the clutch ALL the way in, AND at a dead stop.... my car revs at a high RPM, as if it gets stuck. some guys on here has told me to replace the IAC, so i did, and it STILL does it.... any other suggestions? also, my clutch seems to be loose..... IMO anyway! when i have my foot off the clutch, you can hear it vibrating, and the clutch pedal shakes like crazy as well..... I REALLY NEED SOME HELP!
Thanks, Jeremy
1998 Mustang GT Super Charged! CGS Sub frames, Auto Meter gauges, Bassani Exhaust! |
okay..... well, i guess no one can help me out on this one...
thanks anyways.
hey start by checking the clutch quadrant and linkage under the steering colum the all 3 pedals are linked togheter this might have something to do with your clutch being loose and the gas getting stuck check that out and c if u find anything good luck
as far as your problem with the rpm's i had the same problem with my thunderbird supercoupe, and my thunderbird turbo coupe. it could be the IAC. also it may be the plugs i know when i my turbo coupe i had to gap the plugs alot smaller because i was running around 22 psi, and it caused it to idle very rough
hmmm, yeah thanks guys, i will check that out this weekend! appreciate it
Threads Similar to: still needing help!!!
| problem needing help | Dennis | 96-98 | 8 | July 22nd, 2007 04:49 PM |
| Needing some help w/ my '07 Stang | VOLicious | 2005 - 2010 | 16 | January 1st, 2007 04:32 PM |
| Anyone Needing Anger Management Help? | L33T | The Clubhouse | 3 | October 2nd, 2006 12:08 AM |
| Needing a new altanator should i upgrade??? | RazziGT | 99-04 | 0 | July 14th, 2006 12:11 PM |
| 02 Stang GT needing some PEP | backnblack | 99-04 | 14 | June 4th, 2006 01:50 AM |
