Cooling Issue(s)...
Old December 1st, 2008, 10:23 AM   #1
The Doctor
Lefty's Avatar
'01 Cobra Vert.
iTrader: 11 reviews
Cooling Issue(s)...
96' GT, 5-spd.
My car used to run at the perfect normal temp. The temp gauge needle used to be right on in the middle. Now I just noticed a couple of weeks ago that it is running probably about an eighth on an inch lower from half towards the colder side. And it stays there. Even after about 30 minutes of driving. THEN...sometimes while I'm driving it'll go up to half and keep hauling ass up about another eighth of an inch ABOVE the middle towards the warm side. Doesn't go any hotter. It'll stay up there for about 30-40 seconds then go back down to the "colder" side of the gauge like I mentioned earlier. So I wouldn't say it's overheating, but it is a weird issue. Any suggestions of what could be going on here??? I put a new manifold on (w/ the aluminum crossover) because my stock manifold blew due to the shitty coolant (plastic) crossover. When I replaced the manifold about 5k miles ago I *DID* replace the thermostat. Any help, suggestions, or idears would be appreciated. Thanks guys!
-Troy
Old December 1st, 2008, 06:33 PM   #2
NO_PI_NO_POWER's Avatar
1997 Mustang GT
12.501@116.35
NO_PI_NO_POWER will become famous soon enough
Send a message via AIM to NO_PI_NO_POWER Send a message via Yahoo to NO_PI_NO_POWER Send a message via Skype™ to NO_PI_NO_POWER
Is the new one a PI manifold?
1997 GT
1989 LX ~Dangerously Quick/Needs Battery
Old December 1st, 2008, 06:43 PM   #3
The Doctor
Lefty's Avatar
'01 Cobra Vert.
iTrader: 11 reviews
No, non-pi with aluminum cross over
Old December 1st, 2008, 07:01 PM   #4
1997 Mustang GT
12.501@116.35
yeah, I couldnt tell ya. I know I had problems with my car heating when I put the PI manifold on the npi heads, and just ran heater hose under the manifold insted of the metal hose that is factory.
1997 GT
Old December 1st, 2008, 09:17 PM   #5
Nicks97 is on a distinguished road
iTrader: -1 reviews
Thats not the problem, I bet its the thermostat! 180* replacement would be the best 8$ you ever spent
Due to events on here (like buying a 4000 POS Vortech V2SQ that the seals were out of) (oh, and getting screwed out of another $1000 on here in another matter) I am not gonna be around. Later!
Old December 1st, 2008, 10:25 PM   #6
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
97S281 is a name known to all97S281 is a name known to all97S281 is a name known to all97S281 is a name known to all97S281 is a name known to all97S281 is a name known to all
iTrader: 13 reviews
Is it still well within the normal operating temps?
If it bothers you that much, change the thermostat again.
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Old December 1st, 2008, 10:39 PM   #7
The Doctor
Lefty's Avatar
'01 Cobra Vert.
iTrader: 11 reviews
Yeah, but it just bother's me. Over christmas break I'm gunna put her up on the lift over at the shop and look over everything top & bottom. And probably change the thermostat
Old December 2nd, 2008, 12:50 AM   #8
hbk_136 is on a distinguished road
I would definitely throw in a 180* t-stat in there like he said, and make sure it has or you drill a small 1/8" hole in it to let air past even when its closed to prevent air bubbles in the system.
Threads Similar to: Cooling Issue(s)...
cooling help jtyson8602 5.0 Mustangs 12 October 10th, 2008 12:31 PM
Cooling Down scramblr 2005 - 2010 14 September 9th, 2008 01:22 AM
Cooling usafimj 2005 - 2010 4 June 26th, 2008 12:19 AM
347 Cooling Issue bgddy50 5.0 Mustangs 35 December 27th, 2007 11:34 AM
cooling zhunter V6 Mustangs 2 January 25th, 2006 07:18 PM
