Lifters/lash adjusters
Old December 11th, 2008, 10:49 PM   #1
texas96gt's Avatar
n/a
texas96gt is on a distinguished road
I am thinking about buying some PI heads for my 96gt. The heads are missing the cam gears, lifters, and followers. Are lifters the same thing as lash adjusters. And if so can I use the ones off of my non pi heads? If not are these parts expensive?
BBK CAI, BBK Plenum, BBK 70mm TB, 4.10 gears, BBK o/r H, FRPP headers, 2003 cobra's 255/40/18 front, 285/35/18 rear, Flowmaster 40 series.
Old December 11th, 2008, 11:07 PM   #2
neverfastenough1's Avatar
I would have to say that since they actually look similar to lifters in pushrod motors that it is what they are talking about. I dont have a clue if your old ones will fit or how expensive they are. You could try to find some place on-line that sells the parts and crossrference them unless someone else can tell you if they will work.
Old December 12th, 2008, 12:40 AM   #3
ajm
Theyre cheap. about $10 a piece or you can buy a set of 16 on ebay for around $100
Old December 12th, 2008, 09:20 AM   #4
Randy Stinchcomb's Avatar
1996 Mustang GT coupe
11.99@113.93mph
Randy Stinchcomb will become famous soon enough
lifters and lash adjuster are the samething, followers are what rides off the cam lobes and opens and closes the valves..... if there still in good shape they can be re-used the adjusters and followers.....if the cams are PI Romeo then you can re-use your cam gears, sprockets, spacers, washer but you will need new camshaft sprocket bolts....
Thumbdinger.com Fish With Protection
Old December 12th, 2008, 11:13 PM   #5
texas96gt's Avatar
n/a
Thanks for the info.
Threads Similar to: Lifters/lash adjusters
Valve lash Adjusters interfac9 99-04 31 September 18th, 2008 06:59 PM
Solid lash adjusters zerofx150 99-04 8 March 16th, 2008 10:59 PM
timing adjusters 2000mgt 99-04 7 August 10th, 2007 10:30 PM
Claim Adjusters jmunoz The Clubhouse 17 February 11th, 2007 07:41 PM
