Vortech S trim - Page 3
Old December 16th, 2008, 02:46 PM   #41
jivepepper's Avatar
jivepepper is just really nicejivepepper is just really nicejivepepper is just really nicejivepepper is just really nice
Originally Posted by moosenuk17 View Post
its 4" tubing...
Cool you just need an adapter for the maf to hold a filter.
Sometimes you can get a lightning or SCT 90 mm MAF with the adapter for a sweet deal. Right now you can get a lightning MAF with an adapter for 99 on Ebay shipped. The also have good deals on lightning MAF's with 42lb injectors. But I would suggest the SCT. It's about 100-150 more but you will probably never out grow it.
If you want the KB then get it, but I would consider the KB tuner kit and then find your own MAF, injectors, fuel pump, and tuning solution. I'm not totally sure whats included with their tuner kit so do a little reasearch to see what's the best solution and the best price. It will probably save you money and give you better results.
I would get a SCT 2600 MAF. Good for up to 650-700 RWHP when used with a drawl through set up which a KB is. 42's INJ. good for 500-550 rwhp or 60lb good for up to 650-700 rwhp. Then a SCT tuner of whatever tuning solution the shop where you intend to tune at feels most comfortable with. Regardless of how good KB tells you the tune is you need to at least get dynoed to verify that all your ducks are in a row.
Then a 75 mm throttle body of your choice. I use a cheap Professional products TB and I have been happy with it.
665/541 WHP/WTQ 4.6L SOHC 2V ON 93 OCTANE PUMP GAS.
NO METH INJ., NO E85, NO RACE GAS, N2O BABY BOTTLES!
TRAP=POWER: 11.01 @135, IN SUMMER HEAT, 1350' TRACK, 315/35/17 DR'S
Old December 16th, 2008, 02:49 PM   #42
jivepepper's Avatar
Originally Posted by NavySeabee87 View Post
thats what i keep hearing, but some others say it will peg out. And im pretty sure with vortech the power isnt high enough to make em peg
My vortech would peg the hellout of a lightning MAF unless you buy 175 dollar extender. Then you might as well but the better maf on to begin with.
Old December 16th, 2008, 04:15 PM   #43
moosenuk17's Avatar
2000 ford mustang GT
moosenuk17 is a jewel in the roughmoosenuk17 is a jewel in the roughmoosenuk17 is a jewel in the rough
Send a message via AIM to moosenuk17 Send a message via MSN to moosenuk17 Send a message via Yahoo to moosenuk17
i believe tthe tuner kit comes with the s/c intercooler and chip, i think thats it.ima check
2000 kenne bell GT (440HP-432TQ)
Tuned by Joe at http://www.tricktuners.com
dyno vid:http://youtu.be/lr3xpxw2_v8
2011 escape
MUSTANG TAT CREW
Old December 16th, 2008, 04:39 PM   #44
jivepepper's Avatar
It would surprise me if it came with a chip because you couldn't flash it until you knew what maf injectors were going to be used.
Old December 16th, 2008, 04:46 PM   #45
moosenuk17's Avatar
yea, i just cheked it out, there is no "tuner" kit for the 2.1 KB only the 2.6, so im piecing it together right now, what brand injectors would you suggest?
2011 escape
MUSTANG TAT CREW
Old December 16th, 2008, 05:11 PM   #46
jivepepper's Avatar
hell yeah a 2.6 is a lot better. I would suggest either ford racing 42's, or seimen dekas 60's. 42's or 60's But I would go 60's with the bigger 2.6 if you ever plan on turning up the boost later. The 2.1 would be hard pressed to make 600 but the 2.6 will support 750+ on a 2v.
If I would ever go to a KB it would have to be a 2.6 or bigger.
But since I can upgrade to a T-trim for 500 and support 700+ HP or a YSI-trim for 2400 and support 1000+ HP I'll stick with vortech.
That's why I went with Vortech. The Vortech entry level SC is cheap and it can support 600. It's was the cheapest to upgrade later compared to the other companies and known to be very dependable.
Old December 16th, 2008, 05:17 PM   #47
moosenuk17's Avatar
im goin with KB not so muc for the price as you can tell, but for the fact that they are very reputable, they sound amazing, and punch a lot of power out, but the way you speek, the vortech is very appealing because of price alone lol.
2011 escape
MUSTANG TAT CREW
Old December 16th, 2008, 05:22 PM   #48
moosenuk17's Avatar
would i be able to uswe my JLT with the vortech?
2011 escape
MUSTANG TAT CREW
Old December 16th, 2008, 05:25 PM   #49
jivepepper's Avatar
I would consider Kb for it's power band and they coolnes/sound. Just takes a bigger head unit.
But for max power nothing beats a Turbo. Then a big Centrifuge. After that a big twin screw.
If all 3 head units are the same size, pushing the same amount of boost, through similar combos. It would go like this Turbo>Centrifuge>Twin screw> Roots (Eaton). Turbo being the most efficient and roots being the least.
Old December 16th, 2008, 05:26 PM   #50
jivepepper's Avatar
Nope. They use what's called a powerpipe/inlet pipe like a turbo.
Don't get me wrong KB is one hell of a product. I'm poor so I was looking for the best bang for the buck. I have often dreamed about a 2.8H. It can support up to 900 hp with instant power lol.
Old December 16th, 2008, 05:28 PM   #51
moosenuk17's Avatar
im seriously debating a vortech now, they are way cheaper lol.
2011 escape
MUSTANG TAT CREW
Old December 16th, 2008, 05:31 PM   #52
moosenuk17's Avatar
hook me up jive, what all do i need with the vortech? the best modle for 600-700hp, all components. lol doin some investigating
2011 escape
MUSTANG TAT CREW
Old December 16th, 2008, 05:40 PM   #53
jivepepper's Avatar
If you're sticking around 500rwhp as your max. I think you would be happier with a 2.l KB. But if you plan on making more. unless you want to buy a whole KB kit for around 5K it will cost a lot more later to upgrade. A Kb at the same HP level will have a better feeling of power.
The one thing bad about Vortech is that the base kit is non intercooled. and the IC they offer is expensive, but good. But I have seen one car make 500 non intercooled since they make less heat. I built my own IC set up for 500.
There's pros and cons with both just be sure to think of all the angles before making your purchase.
If you go 2.6h you will not be disappointed.
Old December 16th, 2008, 05:42 PM   #54
moosenuk17's Avatar
alright, thanks, im doin my research right now, 2.6 is lookin good but i dont think im gna go over 500hp
2011 escape
MUSTANG TAT CREW
Old December 16th, 2008, 06:02 PM   #55
jivepepper's Avatar
For 700-800 the T-trim would be good.
But since you do not already have a SC. I would suggest a Paxton Novi 2000 tuner kit. It will support more than the T-trim. I doubt you'll ever out grow it and it works well around 400 rwhp too. Probably one of the best all around SC's on the market. I wish I would have known of it at first, 6 years ago.
It's 3149 but it kicks ass. You still need support mods just like any other tuner kit but it's non intercooled.
SuperchargersOnline.com :: Product: Paxton NOVI 2000 "TUNER" Supercharger Kit for 2001-2004 Ford Mustang with 4.6L (Satin)
They also have a tuner kit for the novi 2000 with an intercooler for 4449. Cost a little bit more. I feel it's the best bang for the buck for anyone wanting to make big power later.
SuperchargersOnline.com :: Product: Paxton NOVI 2000 "TUNER" Supercharger Kit with Air-to-Air Intercooler for 2001-2004 Ford Mustang with 4.6L (Satin).
I would go with 60lb injectors for 600-650 hp. 72's for 700-800.
Maf would be a slot/tonsil style maf from 05 GT and a mafia. Because I would push the air throught the maf not drawl it through like a twin screw usually uses.
Vortech kits drawl through but I converted to a push through. It's just better for Centrifuge SC/Turbo set ups. I'm not sure if there's slotted type maf that will support 800rwhp without a mafia. This is a subject that I also need more info on.
Old December 16th, 2008, 06:04 PM   #56
jivepepper's Avatar
Then I suggest the The KB 2.1.
Old December 16th, 2008, 06:15 PM   #57
moosenuk17's Avatar
yea, thats what i think im gna go for, did you get your professional products TB on e bay?
2011 escape
MUSTANG TAT CREW
Old December 16th, 2008, 06:16 PM   #58
jivepepper's Avatar
Yes.
Threads Similar to: Vortech S trim
vortech T-trim VS S-trim BLOWN89 5.0 Mustangs 20 June 9th, 2008 01:25 PM
vortech jt trim... mystang0673 99-04 2 March 25th, 2008 08:15 PM
Vortech S-trim jblood37 99-04 14 October 6th, 2007 12:51 AM
v1 s trim vortech stoes General Tech 7 March 28th, 2007 11:04 PM
