zippeewannabee
will 315s fit on a 10"?
will they?
![]() Cobb SRI | Eibach ProKit | JBR Short Shift Plate | JBR Rear Motor Mount |
yes, but you will have to roll the fenders
![]() 2000 kenne bell GT (440HP-432TQ) Tuned by Joe at http://www.tricktuners.com dyno vid:http://youtu.be/lr3xpxw2_v8 2011 escape MUSTANG TAT CREW |
They will fit put will look slightly pinched. I rum them on 10.5s.
Why would have to roll the fenders? I have 315's and have room to spare. If I had wider rims I would run 335's
665/541 WHP/WTQ 4.6L SOHC 2V ON 93 OCTANE PUMP GAS. ![]() NO METH INJ., NO E85, NO RACE GAS, N2O BABY BOTTLES! TRAP=POWER: 11.01 @135, IN SUMMER HEAT, 1350' TRACK, 315/35/17 DR'S
1997 SVT COBRA
1996 Mustang V6
![]() ![]() ![]() ![]() ![]() ![]() iTrader: 14 reviews
I had 17x9 with 1 inch wheel spacers.Then borrowed a buddies 17x10.5 wheels with 315 dragradials on them I still had the one inch spacers on and they never hit on my car with the fenders not rolled
I suggest rolling them just in case you have passangers in the back seat it might get close but other then that i would not worrie.
![]() -04 IRS - Magnaflow - Wheel Replica - Autometer - FTBR - FRPP - SCT - Brembo - PRO 5.0 - BOI- |
every time i see a thread about 315's i see the post about having to roll fenders
What a lot people don't consider is the weight of wider tires and rims. Unless you have the power to justify it it will probaly slow you down, but hey, the look badass
#7 | |
But must of the time the rubbing is on the inside so they remove the quad shocks. If you're lowered a lot it might be an prob. Just make sure you get the right backspacing.
i run 345's on 10.5" saleens looks sick
zippeewannabee
damn i bet man... do they fit ok?
any pictures?
That's to narrow of a rim. I bet the side wall bulges a little.
a little but im sending the wheels to weldcraft.... drives fine and hooks hard now cant wait to see it when i get them back
I guess they're 18's? How much power are you making?
#13 | |
Abyssinian of AX
'02 Saleen
19.34@42.259
My sig wheels were widened by them and went to 11's. I have 7~3/8" back-space (this includes the 1/2" spacer) and have "fenders rolled" (< that was for Moose ). I have had to take the hammer to some parts of tub, but not too bad. I no longer have any insulation on e-brake cable where it passes next to, or rather... into, side of tire . I haven't measured, but have additional room I could probably get on fender side. This would mean wider spacer and need to go BACK to Weldcraft to be widened again). I could probably go 1/2" addtional but tire would likely hit on top of tub. This would not be a big deal, but figure you will maybe get 11.5"s to fit, but will need a 5lb sledge to go wider.While you are at Weldcraft, check out the gallery and see my ride ![]() Jazzer
#14 | |
#15 | |
Tyler... your car looks like a freakin steam roller driving behind it haha! Its freakin ridiculous and sexy as fuck!
Wow.... Dont believe everything every noob says on this website. That is
hahaha. Just had to say it.
haha, i have heard if from a lot of people, so please school me on how wide a tire can be without spacers before it rubs usually please haha.
#18 | |
Well actually... wheel spacers wont allow you to run wider wheels if you're lowered in any way. a 285 would rub on the outside fender over any bump you hit. But w/o spacers to answer your question lol... you can run up to a 335 w/o rolling the fenders and messing with your rear suspension. It really depends on the tire though. different brands run different sizes. BFG and MT run wider than most, Nitto and Sumitomo run narrow...
alright, thanks lol, cleared up some miss understanding
Threads Similar to: will 315s fit on a 10"?
| 315s pic | crappy_head | 99-04 | 18 | November 25th, 2008 07:29 AM |
| 315s in winter | knightof206 | 99-04 | 10 | November 24th, 2008 02:26 AM |
| Will a "86" GT Hatch Fit on "87" GT? | The Novice | 5.0 Mustangs | 10 | May 27th, 2008 12:31 AM |
| 65mm outside "tube" size bigger than stock? will this cold air fit a 65mm? | 91cobra5.0 | 5.0 Mustangs | 0 | February 7th, 2008 07:24 PM |
| 15" wheels on a '99, will they and brakes fit? | sweet99 | 99-04 | 3 | January 4th, 2007 08:14 PM |
