car will not stay running at times what could it be ???
Old December 14th, 2008, 11:39 AM   #1
RanGer498's Avatar
2001 Mustang GT
UNKown
RanGer498 is on a distinguished road
Unhappy
Ok here is the whats going on .
my car once in a while will shut off after i have parked it and let it sit for a while.
See I can start the car and get to work with no issues ,but when im leaving work i turn the ignition on, the car turns over but will not stay running .
NOW what i have to do is keep my foot oh so slightly on the gas pedal to keep the car running.if i take my foot off, the car will die regardless if its one min or 5 mins.
so to get home i have to keep my foot on the pedal and put the car in drive and take off.
now by the time i get home (in about 8-10 mins) what happens is
A) the car stays running like nothing was wrong
B) car shuts off ,but if i restart the car and i keep my foot on the pedal for mabe 2-3 more mins that car will not shut off.
When i first noticed this problem i changed the plugs with fresh plugs but the problem still comes and goes.
My car is a 2001 GT
has 62k miles on the motor
oil changed always like normal
fresh plug
no check engine lights on the dash (if there are any)
what could be the issue ?
thanks.
Mods:
-PyPES cat back
-Ford racing springs
-Tires 275/17x9F & 285/18x10R
-S&B Cold air intake
-R498 10" Fixed Black mist Antenna
http://www.moddedmustangs.com/forums/signaturepics/sigpic14989_1.gif
©1969-2010
Old December 14th, 2008, 12:12 PM   #2
Ugmul's Avatar
Ugmul is on a distinguished road
Angry
It sounds like your fuel pump is about to go. Could also be your filter or injectors are clogged up. Should go pick up some SLP cleaning products. Could also swap out the filter.
2002 GT, Mac CAI, Mac LT Headers, L/P Catted xpipe, Magnaflows Magna pack. Xcal3 Custom Tune. Fidanza 2.1 Clutch with Fidanza Aluminum flywheel.
Old December 14th, 2008, 12:58 PM   #3
neverfastenough1's Avatar
Check for any leaks in the air inlet tube and the vacuum hose going to the pcv valve or any other vac lines. Check the pcv valve. Make sure the gap was correct on the plugs. Check the air filter and fuel filter like Ug said. Fuel pump could also be going out as well like Ug said. Thats a start of things it could be. Also could be EGR valve, but I would think that would throw a light. Maybe clean the maf if you haven't.
Old December 14th, 2008, 03:36 PM   #4
bbk03gt24's Avatar
2003 Cobra
bbk03gt24 is on a distinguished road
Send a message via AIM to bbk03gt24
i'm almost 100% positive that i know exactly what it is; your idle control sensor.... the reason why i say that im almost 100% positive is because i had the EXACT SAME thing happen to me in my old 99 gt. it took me forever to figure out what it was, and it actually became very irritating and it also made me look like i didnt know how to drive a stick bc ppl thought that i was stalling out all the time whereas it was really the idle control sensor lol... but anyways, i finally took it to this guy that told me that it might be the throttle position sensor, so i went to advance and bought a new one--throttle position sensor--and that wasn't it, so i started thinking about it, and it only cut off while at idle so i thought, what the hell, i'll try a new idle control sensor and sure enough that was exactly what it was. i took the throttle position sensor back to advance, picked up an idle control sensor, took the old one off and put the new one on and bingo--it started up just as if it were brand new. b4 you go and buy a new fuel pump or etc., i would recommend you trying a new idle control sensor--because it sure as hell worked for me.
2003 Cobra
Stock as of now...
Old December 14th, 2008, 09:28 PM   #5
RanGer498's Avatar
2001 Mustang GT
UNKown
thats all .i know its not my air filter as i clean it every 3 months S&B i was thinking the fuel pump but it would happen more offten than it should if it where i also belive .gaps are on the money i re checked them 4 times .
bbk03gt24 good idea i for got to check the idle air control sensor.
well ill start from the easy to the easy to the hard .
bbk03gt24 about how much was your idle air control sensor?
well thanks everyone for the tips some ideas are better than none .
Mods:
-PyPES cat back
©1969-2010
Old December 14th, 2008, 09:33 PM   #6
RanGer498's Avatar
2001 Mustang GT
UNKown
Operation
The Idle Air Control (IAC) valve controls the engine idle speed and dashpot functions. The valve is located on the side of the throttle body. This valve allows the necessary amount of air, as determined by the Powertrain Control Module (PCM) and controlled by a duty cycle signal, to bypass the throttle plate in order to maintain the proper idle speed.
Testing
1.Turn the ignition switch to the OFF position.
2.Disengage the wiring harness connector from the IAC valve .
3.Using an ohmmeter, measure the resistance between the terminals of the valve.
4.Due to the diode in the solenoid, place the ohmmeter positive lead on the VPWR terminal and the negative lead on the ISC terminal.
5.If the resistance is not 7–13 ohms, replace the IAC valve.
This publication contains material that is reproduced and distributed under a license from Ford Motor Company. No further reproduction or distribution of the Ford Motor Company material is allowed without the express written permission of Ford Motor Company.
AutoZone.com | Vehicle Selection - Year
AutoZone.com | Shopping | Parts | Product Detail - Idle Air Control Valve
$49.99
Mods:
-PyPES cat back
©1969-2010
Old December 14th, 2008, 09:38 PM   #7
The Hammer
G.T. Rags's Avatar
Millenium Falcon
G.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant future
i had the same thing happened to me about a month ago......
never did get around to fixing it.....
hasn't happened since though
I would eat the peanuts out of her shit
Car Salesman Club - The Hammer
ModdedMustangs Conspiracy Group: President
Old December 15th, 2008, 02:27 AM   #8
ZOOTOXIN's Avatar
ZOOTOXIN will become famous soon enough
idle control valve is always going up in these cars. its an inexpensive fix...two srews and a plug and you are done, Unplug the ICV while car is running and see if there is a change in idle,,,if not then there you go,
zo•o•tox•in (zō'ə-tŏk'sĭn)-animal poison; venom
Old December 15th, 2008, 04:29 AM   #9
175lbs of twisted steel and sex appeal
XTCNAGT's Avatar
2007 Mustang GT/CS
XTCNAGT is a glorious beacon of lightXTCNAGT is a glorious beacon of lightXTCNAGT is a glorious beacon of lightXTCNAGT is a glorious beacon of lightXTCNAGT is a glorious beacon of lightXTCNAGT is a glorious beacon of light
Send a message via AIM to XTCNAGT
I'd say IAC also. I had that same issue, and had a buddy bang on it with a wrench. Started working fine. When I took everything apart to change the intake, I took it off and cleaned it real good with carb cleaner and never had another issue.
Well, not with the IAC at least...
I'd clean that the same time you clean your air filter. Doesn't take long. An ounce of prevention is worth a pound of cure.
Old December 15th, 2008, 08:00 AM   #10
~C~
~C~, The Other White Meat!
~C~'s Avatar
Y2K YellowJacket GT
~TBD~
~C~ is just really nice~C~ is just really nice~C~ is just really nice~C~ is just really nice
Send a message via AIM to ~C~
Also, just a dumb thought, but take a look and see if your set screw backed out on the throttle body. If it did, it could explain why it is dropping off right after you let go of the gas.
BLOWN Bumblebeast!
370 rwhp / 381 ft lbs
~Tuned by JJ at WMS
"Like the blind man says......We shall see...."
Old December 15th, 2008, 03:43 PM   #11
ZOOTOXIN's Avatar
+1...I had the same problem at one time. That was a smart thought!!! Hows the BEE running my friend?
Old December 15th, 2008, 03:50 PM   #12
03gtfirered's Avatar
2002 MUSTANG GT
14.2@100
03gtfirered is on a distinguished road
my neighbor has a f150 and he had the same exact problem to the tee. he ran some seafoam through his gas and no problems since. i think its probably a fuel filter clog or dirty injector. try seafoam its only 8-9$ and it cleans your whole fuel system. if it doesnt work atleast your fuel system will be clean lol good luck
______________________________
summit racing catback, bassani o/r x pipe, RAM HDX,jlt intake, mach grill delete, tinted headlights and tail lights!!
Originally Posted by TwirtleNutZ270 View Post
Dude not having a tuner is kinda like having a cake without a fork.
Old December 15th, 2008, 04:37 PM   #13
RanGer498's Avatar
2001 Mustang GT
UNKown
thanks guys how do i go about using the seafoam? I have never done it or see it done.
Mods:
-PyPES cat back
©1969-2010
Old December 15th, 2008, 04:41 PM   #14
RanGer498's Avatar
2001 Mustang GT
UNKown
???correct way????
Mods:
-PyPES cat back
©1969-2010
Old December 15th, 2008, 08:38 PM   #15
I don't think you have a vacuum booster. If you do then yes that will work, but if you have a hydraulic booster you should use the hose going to the pcv valve on the passenger side valve cover.
Old December 15th, 2008, 09:24 PM   #16
mrsinister2424's Avatar
99' Mustang GT
3214@OVER 9000!!!
mrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to behold
Send a message via AIM to mrsinister2424 Send a message via MSN to mrsinister2424
Replace the IAC FIRST, then seafoam. You don't want to potentially complicate any problems by not seafoaming your car correctly
99' Rio Red Mustang GT: --My Garage--
Check garage.
Vortech V-1 intercooled running 9lbs of boost
Life= eat, lift, eat, eat, eat, sleep, repeat
Old December 15th, 2008, 09:37 PM   #17
RanGer498's Avatar
2001 Mustang GT
UNKown
Mods:
-PyPES cat back
©1969-2010
Old December 16th, 2008, 12:14 AM   #18
That one will work, too.
Old December 16th, 2008, 12:48 AM   #19
Novanutcase's Avatar
2003 GT
Novanutcase has a spectacular aura aboutNovanutcase has a spectacular aura aboutNovanutcase has a spectacular aura about
With most problems the solution usually is the simplest. Try the IAC first.
John
SOLD - '03 GT, Max Moto Max Grip Box, Wilwood SL 6 front/DL4 rear Big Brake Kit, Corbeau Seats, MGW Short Shifter, MAC Long Tube Headers/Prochamber mid/ Flowmaster 40, FRPP 4.10, TrickFlow Diff Cover/75mm TB/Plenum, Eaton Posi, Moser 31 spl Axles
Old December 16th, 2008, 10:10 AM   #20
RanGer498's Avatar
2001 Mustang GT
UNKown
John
sea foam is the easiest and cheapest try first
$9.00 sea foam
$20.00 oil change
then ill try the IAC next as my propblem does not happen all the time .
Mods:
-PyPES cat back
©1969-2010
Threads Similar to: car will not stay running at times what could it be ???
88 5.0 sometimes starts but won't stay running cylance 5.0 Mustangs 8 August 28th, 2011 05:59 PM
Got Her Running, But wont stay running...help? Speedstang302 5.0 Mustangs 10 August 28th, 2011 05:58 PM
so i instaled my stereo and now my car wont stay running Dennis Audio/Video 21 May 17th, 2008 07:55 PM
car wont Stay running 01dutchGT Classic Mustangs 8 April 23rd, 2008 02:42 PM
Car wont stay running Spiderz Classic Mustangs 10 March 8th, 2008 08:14 AM
