Door Lock
Old December 14th, 2008, 01:58 PM   #1
SoC@L MuST@ng dRivER will become famous soon enoughSoC@L MuST@ng dRivER will become famous soon enough
Send a message via AIM to SoC@L MuST@ng dRivER Send a message via Yahoo to SoC@L MuST@ng dRivER
Door Lock
Yesterday morning someone tried to break into my mustang. They pulled the lock completely out of the door. amazingly they didnt dent or scratch it thank god. I need to get in there and put the lock back on. How do i do that? Door panel?
[SIGPIC][/SIGPIC]
Old December 14th, 2008, 02:13 PM   #2
ajm
Yea take the door panel off. There is a metal clip that looks like a horse shoe that clips the lock cylinder in place. Shouldnt take you long at all to fix.
Old December 14th, 2008, 02:15 PM   #3
were is the clip located? once i get that panel off i can fix it, i tried taking it off last night, but it was dark so that may have had to do with it.
[SIGPIC][/SIGPIC]
Old December 14th, 2008, 02:16 PM   #4
ajm
Chances are its gonna be laying in the bottom of your door. Its a thin wire shaped like a U with little funny curves on the end. If its not that design then its going to be a flat plate looking thing with a section cut out kind of like this ]
The way it works is the lock cylinder goes into the door from the outside. Then there is going to be a little slot/groove on the cylinder on the inside of the door panel the clip or plate will then slip into that groove holding it in place. Chances are its the design with the plate as the clip is usually used in cars where the lock cylinder is built into the door handle such as an f150. Speaking of that TONS of f150s get broken into this way. All you do is put a flat head in the lock cylinder, slam it in and push up and itll unlock the door.
Old December 14th, 2008, 02:22 PM   #5
Okay. i will do it when i get off. if i have anymore trouble, ill be back on. Thanks
[SIGPIC][/SIGPIC]
Old December 14th, 2008, 02:22 PM   #6
ajm
no problem
Threads Similar to: Door Lock
Driver door lock is stuck. Can't open door Help!!!! White 89 5.0 Mustangs 25 April 26th, 2011 12:49 PM
Door lock problems zombiehouse 2005 - 2010 V6 2 August 21st, 2008 03:14 PM
Frozen Door lock The Novice 5.0 Mustangs 8 August 19th, 2008 05:50 PM
Door Lock Actuators Z28Eater 2.3 Mustangs 4 January 2nd, 2008 02:16 PM
Door lock motors jblood37 99-04 10 April 21st, 2007 09:41 PM
