LinkBack (1) | Thread Tools |
#1
cams and miles on car
Ok I have around 67k miles on my 2000 mustang gt.
Well Im looking at getting the Hi-tech Motorsports stage 2 cams N/A with also a port and polish. Is there anything else I should look at? I figured new valve springs maybe but Im not to bright with all this. Would stage 2 cams be bad for a mustang with 67k miles? What else should I look at getting? I was looking at getting a Trick flow intake manifold(if worth it) Upgrade the TB Upgrade the Pulley system. Im trying to achieve past 320rwhp Mods done already are MAC LT headers LP X pipe Pypes Violater exhaust Diablo tune(which wiht the new cams im sure it get a new tune) Steeda CAI
B&M Short Shifter / Ford Heavy Duty Clutch / 3.73 gears / Nitto Drag Radials / Steeda CAI / Diablo Tuned / Mac LT Headers / Lethal Cated Xpipe / Pypes Exhaust / Smoked headlights and Tail lights / GT floor mats / PP 70mm TB / Accufab Plenum |
2003 mustang gt
yr 1965 @ 88mph
![]() ![]() ![]() ![]() iTrader: 5 reviews
skip the manifold.. And yes your motor will be fine there are plenty of people running alot of power through these motors with much higher mileage.. And i would upgrade the valve springs, and look into the trick flow heads when they come out they will help you achieve your goal..
![]() i'm pretty sure that when i move into my own place i'm gonna mount an anti aircraft gun on my roof with somebody manning it 24 hours a day. why? because it would be fucking AWESOME.[/quote] |
Its do-able but your gonna need one aggresive tune
![]() Mineral Gray Club Member #2 Just your average 22 year old dumbass If you didn't build your car, and your bragging about it, STFU |
no problem with that amount of miles, as long as you take care of your engine you will be fine,
![]() 2000 kenne bell GT (440HP-432TQ) Tuned by Joe at http://www.tricktuners.com dyno vid:http://youtu.be/lr3xpxw2_v8 2011 escape MUSTANG TAT CREW |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 4 reviews
Id skip on the manifold as well, the factory one isnt too bad at all. As for what else to get. Valve springs are definetly a good idea. Youre also going to need head gaskets/bolts and upper intake manifold gaskets in order to do the heads and while youre in there you might as replace the valve stem seals, front cover gaskets, and valve cover gaskets as theyre pretty cheap and can save some time/headache in the future. Also just as the guy above said it wont hurt anything with those miles as long as you keep things taken care of.
2001 Mustang GT
12.4@111 (N/A)
![]() iTrader: 1 reviews
I'd strongly recommend doing the cooling mod when you pull the intake off!
12.4 @ 111mph N/A 2V... (first trip out) in desperate need of a driver mod ![]() N2O times coming soon my junk at the track
#8 | |
Ok thanks Hopefully by next month I can start ordering in the parts. I heard about the trick flow heads. any idea when they are going to be released? Whats the difference between them and the CNC stage 2 heads?
They FLOW ALOT better. The ported heads still have the flow issue and trickflows are completly redesigned. Until the TFS there were no aftermarket heads castings for 2v's. It should be a significant difference. And they are expected anywhere from March-May at most places
Mustang GT
i did my cams at 99k
Stock.....
im doin mine at 70k
2000 GT
I consider 65k low miles! lol. Will be totally fine. And yeah upgrade the valve springs for sure. I would consider doing all this with a tb/plenum combo. Skip the manifold and save the money. I dont think you will hit 320 with p&p heads. Probably with the trick flow you will hit that easy though!
An over looked mod would be aluminum drive shaft, and an efficent water pump. (stewart or electric).
2000 Black convertible GT: KB 15psi, and other goodies... ![]() 1971 Datsun 240 z: Header and rebuilt motor. (The DD) |
2000 GT
I meant to say that you will be over 300 though with p&p also.
opps
665/541 WHP/WTQ 4.6L SOHC 2V ON 93 OCTANE PUMP GAS. ![]() NO METH INJ., NO E85, NO RACE GAS, N2O BABY BOTTLES! TRAP=POWER: 11.01 @135, IN SUMMER HEAT, 1350' TRACK, 315/35/17 DR'S
I did my P1SC at 120k and my T70 turbo at 128k...
www.schradersspeedandstyle.com |
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/101623-cams-miles-car.html
| cams and miles on car | This thread | Refback | December 16th, 2008 12:01 PM | |
Threads Similar to: cams and miles on car
| How many miles on your car? | beefmobile | 2005 - 2010 | 65 | October 12th, 2008 04:31 AM |
| How many miles does your car have? Poll | MustanG_guy17 | The Clubhouse | 45 | February 9th, 2008 01:20 PM |
| Car has a lot of miles need suggestion on what to do to it | GoGetta | 99-04 | 9 | October 6th, 2007 05:28 PM |
| i have a lot of miles on my car but i want a s/c | renemercado | 99-04 | 2 | September 25th, 2007 12:51 PM |
| buying a car with high miles | mustang17 | V6 Mustangs | 7 | May 16th, 2007 01:13 PM |
