13.9@101
Cut FRPP C-Springs
Anyone know how much of a drop it is when you cut the dead coil out of the C-Springs? Pictures would help as well
![]() 13.9@101 before some mods |
2003 Mustang GT
12.28 @ 116
![]() ![]() iTrader: 13 reviews
im assuming you are talking about just the dead coil on the rears. Heres a link to pictures of sweet2kstang's car with c-springs and his rear dead coils are cut look and sound ok???
![]() 2003 Sonic Blue GT---SLP Longtubes, SLP X, Magnaflow Magnapack CB, 75mm TB/Plenum, MP2 Performance stage 2 heads, MHS Stage 3R cams, Built rear w/4.30's |
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
if the springs are new, i suggest to install them and let them settle before you go off cutting the dead coil off. each set seems to settle differently.
13.9@101
The springs have been on the car for about a year. It barely even looks low to me.
![]() and sweetsktang, your rear is a coil cut C-springs, what are your fronts?
13.00 @ 105
![]() iTrader: 1 reviews
I cut a whole coil off the rears (mine were brand new) and left the fronts alone... with isos all the way around....
![]() i only owned the car about 3 more months after that and they had settled very little... here is a friend of mines with a pair of C's about 2 yrs old with all isos:
2001 Mustang GT
12.4@111 (N/A)
12.4 @ 111mph N/A 2V... (first trip out) in desperate need of a driver mod ![]() N2O times coming soon my junk at the track
mm's nitrous mod
2000 mustang gt
i have c-spings all the way around. the rears have the dead coil cut off, and have iso's all the way around as well. the front sits lower now that i have the k-member and cobra a-arms as well, it was almost as low when i was still on stock set up.
best pic i have right now of before the k: ![]() ![]() ![]() docs mach with c-springs:
Abyssinian of AX
'02 Saleen
19.34@42.259
Cutting springs is a bad idea for several reasons, IMO.
1. VERY, if not impossible, to know how much lower you will be. 2. Messes up the rate of progressive springs (and most are going to be progressive) 3. Spring won't fit properly into the perch. It certainly works to lower ride, but comfort and corner performance will suffer as a result. Just keep your ride no lower than 1.5" and accept it as pretty much optimal drop with all things considered. Jazzer |
mm's nitrous mod
2000 mustang gt
itis perfectly fine to cut the rear dead coil off the frpp springs. the frpp springs have a dead coil on it to allow for modifaction just for this. they even send an instruction sheet showing how to do it. the dead coil will not effect any integrity of the spring.
i've cut stock springs before and my car looked great! the only problem is after that the car drove like shit
mm's nitrous mod
2000 mustang gt
the frpp springs are designed to be cut if desired.
Thats because it was not a dead coil.
2001 Mustang GT
12.4@111 (N/A)
correct, it's always been my understanding that uncut is for verts and cut is for coupes.
Threads Similar to: Cut FRPP C-Springs
| 01 GT cut springs | wicked01 | General Tech | 11 | June 14th, 2011 08:25 PM |
| Those with FRPP C Springs | Seabee | 99-04 | 13 | July 11th, 2008 10:34 PM |
| Where to cut rear springs? | 97redgt | 99-04 | 3 | March 31st, 2008 08:56 PM |
| question about frpp springs | blazor | V6 Mustangs | 15 | October 19th, 2007 04:50 PM |
