Cylinder Heads
Old December 26th, 2006, 03:48 AM   #1
Pig Romancer
thewayshemoves's Avatar
2003 GT
300.32@5.02mph
thewayshemoves will become famous soon enough
Send a message via AIM to thewayshemoves
Cylinder Heads
What is the benefit of stage I or stage II cylinder heads alone? I have 1000 to spend at the moment, and I have so many things I can do...I want to do what has the best benefit though. I can spend all of it on some heads, but thats all, is that worth it? Or should I go with something else?
http://i41.tinypic.com/2qjc2mh.jpg
Thank's your a grate guy and person who is good also
Originally Posted by GTsetGO View Post
it ain't no thang ma fraind. i jus be lukin after yo best intrest
Originally Posted by 93hatch View Post
wow open header crx, that things gota sound like hammered dick
Old December 26th, 2006, 04:53 AM   #2
Pig Romancer
2003 GT
300.32@5.02mph
Whats the difference in Romeo and Windsor?
Old December 26th, 2006, 10:34 AM   #3
sonicblue's Avatar
1990 GT
sonicblue is on a distinguished road
i would say get a tuner and gears if you have not done that already. and also i would wait till you can do heads and cams at the same time since you will already be in that area of the engine. romeos have 11 bolts valve covers and windsor 13....i think i got that the right way around.other than that i dont believe there is any major differences
getting all fixed up for next season
2004 mustang gt 520rwhp, 491 trq sold
Old December 26th, 2006, 10:40 AM   #4
Screemin3o2 is on a distinguished road
Send a message via AIM to Screemin3o2
Cylinder heads, displacement, and camshaft or the three main things where you make your power when looking at a longblock. You can make major power through all three, especially cylinder heads. For any amount of displacement, you have to get a set of heads that will flow enough air to make power and you have to get a camshaft that will work the heads correctly to make the power you are looking for. You ca drastically change your power band with a camshaft. You can drastically increase your power with more displacement but you must get a set of heads to flow the amount air that it needs.
That's a basic run through of why heads are important. Your intake manifold is also very important since it is what flows air to your heads. Like I said, very basic. I can get a lot more technical.
95 Mustang GT
Slow Bolt On Car
www.steelcitystangs.com
Old December 26th, 2006, 12:04 PM   #5
MM's nicest mod, :)
White99stang's Avatar
White99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to all
If you have nothing else done i wouldn't go with heads, i would get cams before you get heads. Plus you are going to have to pay for labo somewhere for someone to install them. The difference in the windsor and romeo of course the main one is one was made in windsor and the other was made in romeo plant. the windsor motors were in the 99-mid 01 if i am not mistaken and mid 01 and up are romeo. The windsor has a different water pump pulley, different valve covers, and also contrary to popular belief have a 8 bolt crank instead of a 6 bolt crank on the romeo. You have an 03 so you have a romeo motor. i say go ahead and get you some 4.10 gears and getting them installed is going to take about half your money then go get you a tuner and get the car tuned at a dyno shop to get that little bit extra out of it. and if you have some money left over if you don't have one already get a mac mid-pipe like a off-road h-pipe or a mac pro-chamber. it will help the trottle response quite a bit
06 Dodge MegaCab Diesel 455rwhp/815rwtq
REAL TRUCKS DON'T USE SPARK PLUGS
Old December 26th, 2006, 12:21 PM   #6
RLY SRS
ChrisJ's Avatar
ChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud of
iTrader: 9 reviews
^^^^FTW^^^^
Facebook
Google+
Old December 26th, 2006, 07:16 PM   #7
TrueBlueGT01 is on a distinguished road
I have some mods done to mine now! I have a tuner that should be in tomorrow. I noticed the biggest differences with the 3.73 gears and the mac U/D pullies. That was even bigger than the 75mm T.body and C&L plenum.p.s. mine had exhaust when I bought it so dont know the difference in feel vs. stock.. Hope this helps.
Old December 26th, 2006, 08:35 PM   #8
Make sure your port sizes match from your t/b to your plenum to your intake. you want to make sure they are as close as possible to matching but not larger to get the most out of your heads. And I would wait to buy your heads and cams as a set rather than buying heads now and waiting to get cams later. And do not get a tune yet if you are planning to get heads and cams in the near future.
95 Mustang GT
Slow Bolt On Car
Threads Similar to: Cylinder Heads
Cylinder Heads cbrown 99-04 6 September 6th, 2007 08:49 PM
RHS heads , are they good cylinder heads? hitorx 5.0 Mustangs 25 May 12th, 2007 10:55 PM
SSM cylinder heads for 4.0L V6 DaemonJ V6 Mustangs 6 March 21st, 2007 12:02 PM
cylinder heads help 95StangSVT 94-95 4 December 18th, 2006 06:59 PM
