Cam Question
Old December 26th, 2006, 02:58 AM   #1
Pig Romancer
thewayshemoves's Avatar
2003 GT
300.32@5.02mph
thewayshemoves will become famous soon enough
Send a message via AIM to thewayshemoves
Cam Question
when someone says the stock GT can take a 270 without forged internals, or something...what does that mean? Which number is that? When I'm looking at cams, there are like 6 numbers...which one is the 270 referring to?
http://i41.tinypic.com/2qjc2mh.jpg
Thank's your a grate guy and person who is good also
Originally Posted by GTsetGO View Post
it ain't no thang ma fraind. i jus be lukin after yo best intrest
Originally Posted by 93hatch View Post
wow open header crx, that things gota sound like hammered dick
Old December 26th, 2006, 03:33 AM   #2
Pig Romancer
2003 GT
300.32@5.02mph
http://store.summitracing.com/partde...5&autoview=sku
will that fit in my stock GT safely? this cam thing fucks me all up...makes my brain supernova...I've read so much about them on here and other sites and still can't grasp it...
Old December 26th, 2006, 07:45 AM   #3
mach03 is on a distinguished road
The cam that came up on that link is for a 5.0 push rod motor.
You have a 4.6 2v, wich means you have a cam in each cylinder head.
First decide exactly what you want out of your motor and then contact
a local speed shop that has mod motor experiance or a cam manufacturers tech line.
Old December 26th, 2006, 04:11 PM   #4
Pig Romancer
2003 GT
300.32@5.02mph
I didn't even see what motor it was for hahaha, I know what engine I have, just to clear up the stupidity of that whole thing...I just didn't see that...and why do I have to get two cams in a SOHC? I was looking at all the cams on Summit for my engine, and all of them come with two or four...why would anyone need four? and why do I need two? And why can the 5.0 get theirs for a hundred or so, and I gotta pay like 500? Thats stupid
Old December 26th, 2006, 06:00 PM   #5
TrueBlueGT01 is on a distinguished road
The 5.0 is a pushrod motor = 1 cam the drives every valve in both heads via pushrods..The 4.6 2V is SOHC = 1 cam PER head that almost directly drives valves but only in that head(2valves per cylinder). The 4.6 4V has DOHC = 2 cams per head that drive 4 Valves per cylinder(more flow).. The number 270 is the degrees of engine rotation that valves are open. Raising the duration numbers raises the usable RPM range, but lowers bottom end torque, and makes radical idling sound. But it only works if all other mods promote airflow at that higher usable RPM range. ie,, free flowing exhaust,larger T.body and plenum,larger ports in heads.. Hope this helps!
P.S. The extra expense is for the quantity of steel and machining involved in making all those extra cams.sux doesnt it.
Old December 26th, 2006, 07:46 PM   #6
Screemin3o2 is on a distinguished road
Send a message via AIM to Screemin3o2
tell you what man and don't take this the wrong way. You sound like you really don't know much about how an engine works and that is completely okay because everyone had to learn sometime. Go to Howstuffworks.com and looks for how engines work, etc. That is the place where I first learned about engines when I was 16 and now I can pretty much tell you all about them. That website has wonderful moving diagrams that will teach you a lot. If you have trouble understanding any of it then feel free to ask on here and if you don't get the help you need, PM all you want and I can answer your questions. It's all to teach you.
And by the way, summit has good products in general but you can get outstanding products from other outlets. And by the way, even though that camshaft was not for your engine, FMS were okay in their time, but now they have much better technology in cams.
95 Mustang GT
Slow Bolt On Car
www.steelcitystangs.com
Old December 26th, 2006, 08:39 PM   #7
Pig Romancer
2003 GT
300.32@5.02mph
hmm...I had no idea SOHC had two cams...is it the same in all SOHC? I dunno much about newer engines...I assumed that SOHC was just like you were saying in the pushrod engines had one cam...the shit I can learn from here...thanks for not being assholes like the last forum I asked
Old December 26th, 2006, 08:52 PM   #8
MM's nicest mod, :)
White99stang's Avatar
White99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to all
yeah when they say SOHC thats a cam over the head, if there is only one head then its only 1 cam, if there are 2 heads, say in a v8 or v6 then there are 2 cams, one over each head. DOHC is the same thing, 2 cams per head. Once you actually think about the meaning you will be like oh, makes sense now. Single over-head cam
06 Dodge MegaCab Diesel 455rwhp/815rwtq
REAL TRUCKS DON'T USE SPARK PLUGS
Old December 27th, 2006, 03:34 AM   #9
Pig Romancer
2003 GT
300.32@5.02mph
yeah, I read howstuffworks about it...and it all just clicked, its so simple...the physics are so easy...I can't believe I never read that before as much as I've browsed how superchargers and stuff work on there lol...thank yall...did I ever mention I love yall? in a non-gay way...
Old December 27th, 2006, 08:45 AM   #10
yeah, they make everything very easy to understand and teach you the general basics.
95 Mustang GT
Slow Bolt On Car
Old December 28th, 2006, 08:47 AM   #11
Are you referring to me?
Threads Similar to: Cam Question
88' GT Speedo' Question. Plus Another Gauge Question. Mr_Evil 5.0 Mustangs 8 March 16th, 2008 01:31 PM
Muffler question (visual aspect) + Emblem question warrior86 Visual 5 November 20th, 2007 09:55 PM
