T-3650 ~ T-56 swap in the works... - Page 2
LinkBack (16) Thread Tools
Old December 23rd, 2008, 02:08 AM   #21
SteviGX's Avatar
13.538@101.72 before cams&slicks&gears
SteviGX will become famous soon enoughSteviGX will become famous soon enough
Send a message via AIM to SteviGX
^^^ tko600 is a 6 speed
Mineral Gray Club Member #2
Just your average 22 year old dumbass
If you didn't build your car, and your bragging about it, STFU
Old December 23rd, 2008, 08:38 AM   #22
3rd Place '12 ROTY
Jazzer The Cat's Avatar
'02 GR-40/SLA Saleen
19.34@42.259
Jazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant future
Thanks, Silver
I kinda wish I knew more about ratios and the math that goes into choosing the best one for me, but I don't
I had a 4 speed Vega back in HS days and seems to me the gears were pretty spread out. When I purchased an '85 GT Stang in late '85, I was immediately unhappy with the gap between 4th~5th. I believe it was a T-5, but I really don't know for sure. By the time I purchased my current ride, I was soo used to the gap, I didn't think much of it (the T-3650 is nearly exactly the same). When my current bearings began to howl, I realized I was in need of a rebuild. I posted a couple questions on MF's about new/rebuilt options, and many said "Dude! go T-56 6 speed!". Like this HUGE light went off and realized that was the way to solve this gap .
I did a BUNCH of research and started really thinking about improvements that could be made with different gears. I really only drive my car on weekends, but just want consistant steps between gears. Without doing any of the math to convert RPM's to ratios for PROOF this would be best, I went with what made sense based on my experience.
Looking at the ratios the 2nd~3rd are VERY close and 4th is 1:1, so it's exactly the same. My first is soo low, I have to just about release the clutch with zero throttle to stall it (even then, I have "saved" it a time or two probably due to 3:55's out back). I think this new 5th will be a MAJOR improvement to rid me of the "inbetween" gears feeling I get constantly. Then having 6th, I will see some improvement in mileage and looks to be a nice step from 5th. I have never driven a 6 speed, so I am working on pure theory here, so I hope I am correct.
***HERE*** is the options for the T-56 and, out of all the choices, the #1260 is the best suited as I see it. You can see the Viper spec #1806 and likely runs 4:10s out back and has quite a bit more HP/T than my ride. This is what John Griggs wanted to build for me, but would not want that ratio. Running 245hp/285t, I feel 1st would be too high for a DD with all the hills and SF area I drive.
OK, my computer is about to run out of ink now due to this heafty post , so I bid you farewell until my next update. Hopefully, at my install in a couple weeks
JTC
PS. recieved my Pro50 shifter yesterday, so I am 100% set on all the parts I need EXCEPT MY BUDDY TO GET OFF HIS ARSE AND HELP ME WITH INSTALL
Old December 24th, 2008, 04:47 AM   #23
EThompson6 is infamous around these partsEThompson6 is infamous around these partsEThompson6 is infamous around these partsEThompson6 is infamous around these partsEThompson6 is infamous around these partsEThompson6 is infamous around these parts
no its not. what are you smoking?
Tremec Transmission for TKO 600 - (0.64 Fifth Gear Ratio) - StangSuspension.com
Auto response from SoCaLMuSTaNg7: ed is amazing
Old December 26th, 2008, 10:24 PM   #24
3rd Place '12 ROTY
19.34@42.259
I am going out of my brain here....
I ordered a new billet flywheel today and T.O. bearing, as clutch and pressure plate only have about 15K on them. The bearing was also replaced at the time, but cheap enough to install a replacement. I will also re-imploy my trick to pull the bearing off of the pressure plate. The Ford design is to utilize a "continuous spinning" bearing and The Jaz don't like that! I actually have a short video I took of it in action:
The metal rod is the end of the clutch cable and bearing is being pulled left to contact pressure plate. When the clutch is out, the magnet pulls the bearing away. Pretty tricky... eh?
I also received my Pro50 shifter the other day, so just about all set of Jan. 10th install, bay bay
The following is an ACTUAL photograph of The Jazzer, taken earlier today:
Please approach with caution as it is getting dangerous around here!
Old January 10th, 2009, 09:30 PM   #25
3rd Place '12 ROTY
19.34@42.259
OK, pepes.... didn't get done, but MAJOR progress
Ran out of time today as my buddy and I had to spend 1.5 hours JUST making enough room to get my car up on the lift. The shop has 7, count 'em, SEVEN major resto projects going with pretty much zero done on any for many a year!
Anyway, we did all the hard stuff today, and even found a missing nut on the passenger side of exhaust manifold causing a small leak and will be fixed. The old trans came right out, and the new one went right in. I had read MANY times of the "massage" work needed in the tunnel for install, but seem to have lots of room. Passenger side has 1/2" all around at closest point and driver side (the side that will see the most movement at WOT), had nearly 1". OK, now some pics:
This is the existing clutch and pressure plate with a new FRPP billet fly. The clutch has about 15K on it and my buddy was pointing out the surface and said it appeared to have about 200 miles on it, at most! Installed a new T.O. bearing and reusing the clutch fork that was installed at same time as clutch, last year.
Here it is just installed and ZERO tunnel work needed to fit. Just the cross-member bracket needed and some wiring for reverse switch needed:
Completely installed along with new aluminum drive-shaft (1" shorter than previous one) and all toqued in. Once it was all installed, the clearance was still really good, so cannot see why all the installs saying tunnel work was required. The cross-member was for a Cobra and may not have even been needed. The "nuts" on the body are actually a sliding part that have alternate holes that are oval to line-up cross-member and would probably have worked with stock one. The Cobra one fits VERY nicely and was worth it either way:
Here is the reverse switch that is now connects on the passenger side. The wires had to be extended 1' to reach over the trans. I just cut the two wires and soldered two 1" pieces of wire inbetween and applied heat-shrink tubing as protection. I then wrapped the two wires with electrical tape so they would remain clean and not tangle up on anything. I also had to rob the reverse switch from my old T-3650 as the connection "posts" of switch were not only too large, but not on the same center:
The speedo connection went right in and don't see any other obsticles so far. We will hit it up tomorrow morning and get 'er done, as we just ran out of time today . We will also have to machine a new clutch spacer as the Ford cable has NO adjustment and is just a solid line with pressed ends on it. Appearantly, the T-3650 bell-housing is just a little deeper or something and the clutch cable is now about 1" too long. This is no prob, as Wes is good at machining stuff.
Will finish up and take a roadie with the galpal tomorrow and give y'all a little review of how it drives.
Jazzer
EDIT: I almost forget.... MAJOR props to Bruce at Modern Driveline for all his help. Bruce was absolutely wonderful from start to finish on this project. He helped me diagnose the "howl" issue I had with my T-3650 and worked with me on how to address it. I mentioned that I was unhappy with the ratio's and was told a T-56 was the way to go. He looked at all the options and came up with the 1260 as a suggestion. I was VERY happy with the ratios and he hooked me up with the cross-member and confirmed a direct fit into my ride. Just this past Tuesday, he spent about 10 minutes on the phone trying to locate me the proper flywheel as the Ford dealer could not locate one in time. I received it the next day and was a perfect fit. Even got me a new set of bolts/dowl pins so it would all go together well as the 10.5" and 11" clutch need different bolts to anchor pressure plate.
Thanks Bruce
Old January 10th, 2009, 09:35 PM   #26
The Doctor
Lefty's Avatar
'01 Cobra Vert.
iTrader: 11 reviews
I'm excited.
That is all
Old January 11th, 2009, 09:25 PM   #27
3rd Place '12 ROTY
19.34@42.259
She's Alive!!!!
Got 'er all finished up this afternoon and is wonderful . Running a little bit taller 1st gear so going into 2nd is a bit smoother. Nice and buttery shifting thanks to a nicer transmission as well as the new Pro50 shifter Fixed a small exhaust leak while we were under there and happy as a pig in poop . The galpal and I are going to take a little road trip here in a few for a little more of a test drive. So far, I have not found reverse except when looking to find it. It is a little strange to push the stick over and forward to get into it though, been driving two different 5 speeds for about 23 years and reverse has ALWAYS been over and back. I have had a bit of trouble finding the proper gear when coasting to a stop and light turns green. You know, kind of floating at 15mph and look for 2nd and found 4th a time or two. This will not be an issue for long as I am not use to how close the gears are to eachother. The reverse lock-out spring is absolutely purrfect! Just enough resistance to "want" reverse and not just fall into it. Over time, I may decide to remove the spring altogether, but so far, seems just fine
I needed to make/install a new clutch return magnet and hence a new video uploaded to Streetfire. I posted a fresh link in the original post, but seems to make sense to upload it here as well. The lighting is MUCH improved as my video skills are now completely mad!
EDIT: for whatever reason, the image is not displayed, so click link on top of picture below
That thin curved piece is actually 1/2 of a hard-drive magnet set-up with a VERY strong magnet. It doesn't actually touch the clutch fork, yet has plenty of strength to pull T.O. bearing away from pressure plate. This should help extend the life of the bearing and has a nice little "release" of pedal when depressed, yet does not add resistance as a spring would.
Ok, pepes.... I'm outty
lé Gato dú Jazzee
Old January 11th, 2009, 10:47 PM   #28
The Doctor
Lefty's Avatar
'01 Cobra Vert.
iTrader: 11 reviews
I'm Jealous. Very Jealous.
Old January 18th, 2009, 09:12 PM   #29
3rd Place '12 ROTY
19.34@42.259
AWESOME!!!
Anyone considering this swap, is well advised to do so
1st~2nd is nice and smooth now, and less likely to get a herky-jerky as the ratio is much closer. That is not all folks, just check what's behind door #2... The loss of the 4th~5th gear gap I am now able to cruise at 55 mph with no need to choose between 2600 rpm 4th or 1600 rpm 5th With the new T-56, she now runs at 2200 rpm in 5th so have some power for those little hills in Marin Co. I always hated having to drive a little faster than I would like JUST to retain some semblance of HP in 5th gear.
This is a spectacular upgrade and recommend it to anyone with the means to do so
Jazzer
Old January 18th, 2009, 09:40 PM   #30
The Doctor
Lefty's Avatar
'01 Cobra Vert.
iTrader: 11 reviews
Originally Posted by Jazzer The Cat View Post
AWESOME!!!
Jazzer
When I want to upgrade my Tranny you're coming out here and we're doing the install...
Okay, good?
Old August 21st, 2009, 10:14 PM   #31
MM's Mad Scientist
acmillr's Avatar
Slow Fella
acmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to behold
I know this is an old thread, but do any of know if the T56 wiring harness from an 03 Cobra will work with the 03GT motor and computer harness. I have been unable to locate a pin position diagram for either tranny wiring harness. I know the 03 Cobra harness should have two extra pins for the lock out, but is everything else pinned in the same location?
Old August 21st, 2009, 10:26 PM   #32
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
if i remember right, the pin location is the same for manual to manual. the auto's are different. i will see if i can get a hold of 1 of 2 guys that i think have the pin diagram for it.
Old August 21st, 2009, 10:31 PM   #33
MM's Mad Scientist
acmillr's Avatar
Slow Fella
Thanks
Old August 22nd, 2009, 12:24 AM   #34
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
one guy got rid of his harness, and cant get a hold of the other guy. what i have gathered is that the swap guys are using the harness from their t45 or tr3650 and using it on the t56. the harness is a direct plug in from what i have read, the t45 guys just have to use the t45 reverse switch on the t56. they get the f-body solenoid for the reverse lock out. not sure how much this helps, sorry i cant be any more help.
Old August 22nd, 2009, 12:31 AM   #35
3rd Place '12 ROTY
19.34@42.259
A little late in the convo here, but FWIW, I will add this. The reverse switch is on the opposite side of the trans from the T-3650 to the T-56. The "spread" of the pins differs as well as the length of the harness. I had to rob the reverse switch from my old T3650 and install it in the new trans to make the connector work.
Jazzer
Old August 22nd, 2009, 02:37 PM   #36
MM's Mad Scientist
acmillr's Avatar
Slow Fella
Good deal, I think I got it licked.
Old December 6th, 2009, 11:56 PM   #37
Look Ma! My First Post!
98 Mustang Cobra Convert
GT350H is on a distinguished road
Reverse Lockout Mod
Jazzer, I'm new to this forum and am swapping a Ford T-56 for the T-45 in my 98 Cobra. I'm really interested in the details of the reverse lockout modification. That sounds like the perfect solution.
Also would like to tap your experience as to correct bellhousing and driveshaft, and your sources for same.
Old December 7th, 2009, 01:59 AM   #38
Ryguy33's Avatar
2002 Mustang Gt
3 seconds......flat
Ryguy33 will become famous soon enough
Send a message via AIM to Ryguy33
hey jazzer if you still have your T-3650 i might be interested in taking it off your hands
Mods = stuff to make me take corner faster
Old March 13th, 2010, 03:06 PM   #39
bullitt2722gt is on a distinguished road
t56 swap
im new to the board and found your post on the t56 swap. Im doing the same and was woundering if anyone knows if the t56 trans wiring harness will plug in to the 2001 bullitt/gt harness? see the tranny i bought came with the harness, crossmember,the 03 04 drive shaft, fly wheel and clutch. and was hopping it will plug in.
Thanks for your time
Old March 13th, 2010, 06:45 PM   #40
cjuni is on a distinguished road
I believe this is all you need, im goin doin the same thing currently......but please correct me if im wrong guys!
PARTS LIST !
T-56
CLUTCH & FLYWHEEL KIT ( ONLY if input shaft is not a 10 spline )
recomend SPEC 3 + with billet steel flywheel
new ford throwout bearing
T-56 SHFTER
03 COBRA TRANS MOUNT BUSHING
03 COBRA PINION FLANGE ( BEST WAY TO DO IT )
03-04 COBRA DRIVE SHAFT
DALLAS MUSTANG SPEED CAL the link is the right one you need part # DED-RANGE/7626
drill hole in subframe for new hole for mounting position of trans mount
and the description for reverse lockout that fstcobra2 put up cause ITS TAKES 2 HANDS TO PUT IT IN REVERSE WITH THE LOCKOUT IN PLACE LOL !!!!
one thing to add here if you have T-56 out of a 00-cobra R you use a T-45 trans mount.
if you have one out of a 03-cobra then use a 03 mount of course lol
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/102262-t-3650-t-56-swap-works.html
Mid-Atlantic Domestics Car Club - Official Website - A Mid-Atlantic Region Car Enthusiast Community! • View topic - New Tranny This thread Refback October 26th, 2011 12:31 PM
Mid-Atlantic Domestics Car Club - Official Website - A Mid-Atlantic Region Car Enthusiast Community! • View topic - New Tranny This thread Refback October 24th, 2011 07:50 PM
Mid-Atlantic Domestics Car Club - Official Website - A Mid-Atlantic Region Car Enthusiast Community! • View topic - New Tranny This thread Refback October 24th, 2011 06:47 PM
Mid-Atlantic Domestics Car Club - Official Website - A Mid-Atlantic Region Car Enthusiast Community! • View topic - New Tranny This thread Refback October 24th, 2011 06:27 PM
Montreal Mustang > jme questionne This thread Refback September 25th, 2011 01:17 PM
jme questionne - Montreal Mustang This thread Refback July 3rd, 2011 10:27 AM
jme questionne - Montreal Mustang This thread Refback July 2nd, 2011 11:48 PM
jme questionne - Montreal Mustang This thread Refback July 2nd, 2011 11:12 PM
jme questionne - Montreal Mustang This thread Refback July 2nd, 2011 10:22 PM
jme questionne - Montreal Mustang This thread Refback July 2nd, 2011 10:07 PM
The daily driver is turning into a daily driven project. This thread Refback March 30th, 2011 12:53 PM
The daily driver is turning into a daily driven project. This thread Refback March 30th, 2011 01:43 AM
T56 Reverse Lockout - SVTPerformance This thread Pingback January 8th, 2011 03:53 PM
just installed viper spec t56 *PICS* + Questions! - SVTPerformance This thread Pingback May 30th, 2010 04:28 PM
Daggum Car - Insane Mustangs, GT, Saleen, Roush, Cobra This thread Refback February 2nd, 2009 08:24 PM
T-56 change out. - North Carolina 2 Texas Racing This thread Refback February 1st, 2009 10:57 PM
Threads Similar to: T-3650 ~ T-56 swap in the works...
T-3650 UnixHH 99-04 34 January 9th, 2009 10:31 PM
tr 3650 superbeef1000 99-04 4 October 31st, 2008 01:27 PM
3650 tommyd04gt 99-04 2 October 1st, 2008 10:49 PM
My 3650 is different from a 05 3650??? smccoy916 99-04 15 September 30th, 2008 11:57 PM
tr-3650 emgjsdk1 99-04 18 May 10th, 2008 09:23 PM
