I Poop Entirely Way Too Much
Blown 03 GT
Pulling the motor, need some advice.
I searched through a bunch of old threads but Im still not sure the best route for me. My motor blew and Im replacing the motor. Im doin this in my driveway and dont need to remove the tranny for anythin. How hard is it to get to the bolts mounting the tranny to the engine? Is it easier to just remove the engine and tranny together or should I unbolt it and just pull the engine?
easier just remoning the tranny to.. those bolts are a bitch
built motor,trickflow heads,logan intake,80mm comp turbo on the way..
It will come out just fine with the tranny on. All of the swaps weve done, we have the tranny on for install and pulling.
If you have headers, when the motor is up, drop the K to allow more room.
![]() Trevor 2004 GT HiTech Motorsports Stage 2 Cams
300/309 12.16@112 |
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
its not bad. me and a friend can have the engine on a stand in 3 hours easily in 3 hrs.
2000 Mustang GT Conv.
Definitely, leave the engine/tranny together and pull/install as a unit. Much easier (Just did it by myself with a good engine hoist and load leveler).
mm's nitrous mod
2000 mustang gt
no way in hell you going to catch me pulling the both together without the front end being apart. i drop the k, then lower the motor/trans together lo enought to get headers and trans off. then just pluck it strait out the top.
Proud American
taking out the tranny or unbolting it first is how i would do it... it requires drppin the K member to get both out with the angles at least did on mine. this time since i have no tranny in it, it should just pull straight out the top!
+1
665/541 WHP/WTQ 4.6L SOHC 2V ON 93 OCTANE PUMP GAS. ![]() NO METH INJ., NO E85, NO RACE GAS, N2O BABY BOTTLES! TRAP=POWER: 11.01 @135, IN SUMMER HEAT, 1350' TRACK, 315/35/17 DR'S
Dont need to drop the K or take off the trans. just get a buddy to help and take em out together - it isnt hard.
Accufab 75mm tb & plenum MRT h-pipe Flowmaster catback FRPP king cobra clutch FRPP aluminum driveshaft FRPP 4.10 gear TA Perfromance girdle Steeda tri-ax shifter Moser 31 spline axles FRPP C Springs |
mm's nitrous mod
2000 mustang gt
dropping the k is easy, makes things easier and faster.
#11 | |
Blown 03 GT
I have stock headers so Im gonna try and pull it it all out together, sounds like itll make it easier. Will the tranny leak when the drive shaft is removed?
#12 | |
2011 Mustang GT
12.1 @ 116
![]() Drain it.
Mods in garage. Built suspension and gears since posted times. |
Blown 03 GT
I just filled it RP this summer
2011 Mustang GT
12.1 @ 116
When you drain it, just get a clean bucket and put the fluid in there, then funnel it into a jug to put back in at the end of the job...
mm's nitrous mod
2000 mustang gt
once the drive shaft is pulled, it will leak. that is why i drop the k, i lower the trans at the same time and leave the d/s in. get them to the ground, unbolt the trans and k when you lower them together, and lift the motor strait out.
2011 Mustang GT
12.1 @ 116
Never thought of doing it that way. That would make doing a clutch a 3 hour ground job... I may just do this next time.
mm's nitrous mod
2000 mustang gt
i do the clutch in 3 hours from the time i pull car in to the time i take it out to test drive.
Blown 03 GT
Sweet2k sounds like you got it down pretty well. Could you throw a quick step by step list together? I think I got a it pretty good but Im not certain.
mm's nitrous mod
2000 mustang gt
thats a long list. i will try to get one together asap.
#20 | |
2011 Mustang GT
12.1 @ 116
Is the method above (dropping K member and letting entire drivetrain sag) the way you do a clutch? When I did mine, I just took the tranny out.
Threads Similar to: Pulling the motor, need some advice.
| motor advice | 98srsmustang | 4V / SVT | 28 | June 23rd, 2008 03:09 PM |
| R.I.P motor need advice | gotn20 | 5.0 Mustangs | 7 | May 18th, 2008 09:38 PM |
| Pulling Motor | wraitherx | 5.0 Mustangs | 18 | March 14th, 2007 05:07 PM |
| pulling engine need advice. | hawaiiankine | 5.0 Mustangs | 10 | March 4th, 2007 11:34 PM |
| Replacing An Oil Pump Without Pulling The Motor | JamesR1 | 5.0 Mustangs | 1 | September 17th, 2006 01:57 PM |
