No time better than the present. J/K If you do not plan on running sticky tires In my opinion I would not worry about it.
if you are going to run a sticky tire, and will be doing high rpm clutch dumps, better upgrade the axles and differential. you will be on borrowed time on the 28 spline stuff.
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
i still unfortunatly have 28 splines and ran out of money before i got the 31 set up. i have bolt ons and put on slicks and so far they have held up. but now i have the vitamin N2O and hope to have a 31 set up before the season starts. average people dont really need it but if a little abuse is in plans then its worth the $$$
just a note, when it's time don't forget some OE aplications have 31 spline carriers in 8.8 housings. If your up to the task you can save a few bucks for gas by putting hp clutch discs in those carriers then a set of good axles and your good to go.
#7 | |
Threads Similar to: Rearend
| What rearend does my 89 gt have | White 89 | 5.0 Mustangs | 5 | October 4th, 2007 04:56 PM |
| Rearend ?? | Stang6899 | V6 Mustangs | 6 | September 21st, 2007 06:47 PM |
| rearend-tranny ? | theyanks904 | V6 Mustangs | 130 | August 15th, 2007 06:29 PM |
| what rearend should i use? | etony89 | 5.0 Mustangs | 26 | May 26th, 2007 07:59 PM |
| 9 in rearend? | solareclpse2000 | 5.0 Mustangs | 7 | January 9th, 2007 09:25 AM |
