Gears Auto vs manual & hp loss auto vs manual
Old December 24th, 2008, 02:33 AM   #1
jivepepper's Avatar
jivepepper is a jewel in the roughjivepepper is a jewel in the roughjivepepper is a jewel in the roughjivepepper is a jewel in the rough
If the 4R70W as a 3rd gear ratio of 1 to 1 would I be fine at the track with the 3.73's I have now. Will I run out of gear, or be geared to high now?
How much hp will I lose on the dyno compared to the standard. I have dynoed twice on two different dynos one was 572 and the other was 598. The one I go to regularly seems to read lower than others I have been on.
I know I have had a lot of auto tranny questions lately but I'm in the research and development stage of my swap lol. Prepared to be bored with newb question over the next 3 months or so.
2000 GT 665/540rwhp/rwtq
Best 1/4:
AT 431HP 12.29 @ 124
AT 515HP 11.24 @ 129
AT 638HP 11.01 @ 135
AT 665HP ??.?? @ ???
80*+day, 1400' track, 10.5" DD Cobra R's & 315/35/17DR'S
Trap speed = true measurement of HP.
Old December 24th, 2008, 03:02 AM   #2
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
the better the parts you install in the auto set up, the less parasitic loss you will have. a good converter, manual valve body, and if you were to do clutches etc, loss will be the same as a manual trans. if you are passing thru the traps now in 4th, you will be doing the same in 3rd as the manual. i personally would go a 4.10 with an auto, the auto can fully utilize the steeper gear.
Old December 24th, 2008, 03:16 AM   #3
jivepepper's Avatar
I'm right at the end of my power band with the 3:73's. I have hit the rev limiter right after the traps because I held it a little long. Do you still think I could take advantage of the 4:10's?
Best 1/4:
Old December 24th, 2008, 03:16 AM   #4
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
yes.
Old December 24th, 2008, 03:17 AM   #5
MasterDeBater
Smoothgrandmama's Avatar
12 GT
8.46@88 1/8
Smoothgrandmama is a jewel in the roughSmoothgrandmama is a jewel in the roughSmoothgrandmama is a jewel in the roughSmoothgrandmama is a jewel in the rough
iTrader: 6 reviews
Send a message via AIM to Smoothgrandmama Send a message via Yahoo to Smoothgrandmama
You will be in overdrive
Join The MM Facebook:
Modded Mustangs Facebook
Vote For Modded Mustangs Ride of the Month
Eskimo Brothers To Smooth: Safi, Blitz34, Graystang01, WillTheThrill, Bwal
Old December 24th, 2008, 03:21 AM   #6
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
the transistion time for shifting in a manual, gear ratio between the manual and auto, power curve, etc will allow the auto to fully utilize the steep gearing. the first 300ft will be a huge difference just going to the auto. the steep gearing goes thru so fast in a maual car, an auto can (usually) plant the power a lot better and deliver the full use of the gearing/torque. not to mention the auto will absorb shock a lot better than slamming the gears in a manual.
Old December 24th, 2008, 03:25 AM   #7
jivepepper's Avatar
I do not want to be in overdrive acrossing the traps I'm affraid I'll burn it up.
Best 1/4:
Old December 24th, 2008, 03:36 AM   #8
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
then you amy want to go to a 3.55. going into 4th isnt what hurt a trans, its when you run fast enough that the converter tries to lock up. when the converter tries to lock up at those speeds, is when damage will occur.
Old December 24th, 2008, 03:46 AM   #9
jivepepper's Avatar
I will have the od and the lockup on toggle switches, but I plan engaging it after shifting to 3rd.
Best 1/4:
Threads Similar to: Gears Auto vs manual & hp loss auto vs manual
Auto to Manual smccoy916 99-04 38 September 19th, 2008 07:42 PM
Auto To Manual Youngin The Clubhouse 60 June 30th, 2008 11:23 PM
Auto to Manual... WILD Jeff 2005 - 2010 9 March 4th, 2008 07:29 PM
auto or manual zhunter V6 Mustangs 21 July 6th, 2007 02:25 AM
