cam install
Old December 25th, 2008, 03:04 AM   #1
spike spiegel's Avatar
spike spiegel is on a distinguished road
cam install
just curious what shops usally charge for a 2 install cams?
can i tune my cam
with a hand held tuner,closest dyno is 2 hrs away
I almost have enough money for the cam with my xmas money
thank you merry xmas
[2000 blue mustang gt vert 5spd,stalker bodykit,18'' cobra rims,lowered 2'',light bar,k&N cai,roush side exhaust,x pipe,pp 75mm tb & plenum Pro5.0 3:90 gears,Custom 91 octane SCT tune 2000 red VW jetta,auto stock
Topless Mustang Club Member
Old December 25th, 2008, 10:20 AM   #2
Mustang GT
2000ZincGT will become famous soon enough
I dont know what they charge but if i were you i would just get some CMS stage 1's and do it myself. Being that you have a 2000 you will need to buy cam gears to, I have some if you need em. Its a pretty simple job. I did Comp Cam 270's and pulled the heads to do the valve springs that will make everything alot more time consuming.
Stock.....
Old December 25th, 2008, 12:14 PM   #3
ajm
Do it yourself or save for fi would be my opinion. By the time you buy the cams, springs, gears (if needed), the cam gear bolts and crank bolt, any gaskets you may need to or decide to replace along the way, plus labor it wouldnt be much more to go fi. Install isnt hard.
Old December 25th, 2008, 12:57 PM   #4
07 gt
chefalan23 will become famous soon enoughchefalan23 will become famous soon enough
to get cams and valvesprings installed its going to be about 1000 bucks. not money well spent if you ask me.
07 GT 5spd Black on Black
BBK Equal Length Shorties
4.10s
FRPP K springs
JLT with canned tune
Pypes O/R H
Pype Bomb axleback
Steeda UDP
Old December 25th, 2008, 01:36 PM   #5
slow02gt's Avatar
2002 mustang gt
11.38@119
slow02gt is a jewel in the roughslow02gt is a jewel in the roughslow02gt is a jewel in the roughslow02gt is a jewel in the rough
Send a message via AIM to slow02gt
you can adjust it with a programmer to where it will run ok... but you need a dyno so you can actually get your power adjusted right.. you can run cams untuned they just run like complete shit... you need to know where you air/fuel is at if you play with the programmer
built motor,trickflow heads,logan intake,80mm comp turbo on the way..
Old December 25th, 2008, 10:56 PM   #6
beast5319 is on a distinguished road
+1
2000 AUTO GT (TOTALED): 17 inch anthracite bullit wheels (apparently 05+'s), chin spoiler and grill delete, tint. flowmaster 40 weld ons, sct x3 (FOR SALE!!!), 1.5" drop, 1" wheel spacers, and 4.10's (most of this stuff is ruined)
Old December 25th, 2008, 11:01 PM   #7
moosenuk17's Avatar
2000 ford mustang GT
moosenuk17 is a jewel in the roughmoosenuk17 is a jewel in the roughmoosenuk17 is a jewel in the rough
Send a message via AIM to moosenuk17 Send a message via MSN to moosenuk17 Send a message via Yahoo to moosenuk17
i bought cams and sporings, do i NEED to do my cam gear? or is it recomended? same with the cam bold and crank bolts
2000 kenne bell GT (440HP-432TQ)
Tuned by Joe at http://www.tricktuners.com
dyno vid:http://youtu.be/lr3xpxw2_v8
2011 escape
MUSTANG TAT CREW
Old December 25th, 2008, 11:11 PM   #8
ajm
Cam gear bolts and crank bolt is needed since theyre TTY. The gears,spacers, and washers are needed unless youve got a romeo engine.
Old December 25th, 2008, 11:36 PM   #9
moosenuk17's Avatar
thank you
2011 escape
MUSTANG TAT CREW
Threads Similar to: cam install
Cam install usafimj 2005 - 2010 35 March 4th, 2010 06:01 PM
cam install jerseymike Modular Mustangs 17 June 27th, 2009 06:47 PM
Cam Install? beastGT 2005 - 2010 44 August 28th, 2008 11:43 PM
Cam install ?'s pfcbrook 99-04 12 February 29th, 2008 08:11 PM
cam install 95blueGT 94-95 4 October 12th, 2007 01:56 AM
