steeda tri shifter...any help?
Old December 25th, 2008, 02:28 PM   #1
blue03mach1 can only hope to improve
so i got a bunch of things from my parents today, some things for my car, like long tubes, set day for dyno tune and steeda tri ax short shifter. so i was trying to remove the old hurst shifter out of the mach and for some reason the fuckin sealant that keeps the fums from coming into the car is like hardcore glue , well i tried everything to remove the other shifter, i even used a fuckin cro bar to try to get it off. Any ideas on how to get it off?
Old December 25th, 2008, 02:33 PM   #2
2003 Mustang GT
Faster than a Yugo
NickM is on a distinguished road
If you are talking about removing the shifter from the trans., the instructiions say to bollt the stick back on and use it as a lever.
That's what I did and it worked like a charm.
Nick
Old December 25th, 2008, 02:38 PM   #3
i tried that, its really stuck on there. i've tried everything.
Old December 25th, 2008, 02:39 PM   #4
and yeah thats what im trying to do.
Old December 25th, 2008, 02:47 PM   #5
mrbigjeep's Avatar
04 mustang gt
7.21 @ 98
mrbigjeep is a name known to allmrbigjeep is a name known to allmrbigjeep is a name known to allmrbigjeep is a name known to allmrbigjeep is a name known to allmrbigjeep is a name known to all
man i had the same problem...i bolted the shifter back on and then pushed to the right (the transmission is gonna move some) and gave it some force and it broke the seal and came right off.
cams + 150 shot
Old December 25th, 2008, 02:54 PM   #6
ahh ive tried that... still doesnt even budge. i moved the tranny too.
Old December 25th, 2008, 03:00 PM   #7
mrbigjeep's Avatar
04 mustang gt
7.21 @ 98
go right and then left and then back to the right and just push...mine popped off. or i might have slammed it to the right with a lot of force.
cams + 150 shot
Old December 25th, 2008, 03:08 PM   #8
haha ive tried that man, idk just cant seem to get it off. thanks for the help tho.
Threads Similar to: steeda tri shifter...any help?
Steeda Tri-ax shifter fastford3388 5.0 Mustangs 4 May 7th, 2008 01:45 PM
Steeda tri ax shifter?? jam77 5.0 Mustangs 5 June 13th, 2007 09:11 PM
