Nitto 275s on 15x7 Wheel
Old December 26th, 2008, 09:11 AM   #1
MyGT's Avatar
13.1@105
MyGT has a spectacular aura aboutMyGT has a spectacular aura about
iTrader: 6 reviews
Will there be any issues?
2009 Super-Stangs Fantasy Football League Champion
Thanks Brees!
Old December 26th, 2008, 12:03 PM   #2
3rd Place '11 ROTY
Jazzer The Cat's Avatar
'02 GR-40/SLA Saleen
19.34@42.259
Jazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant future
A 275 is WAAAYY too much tire for a 7" wheel
You are looking at a 225 in most brands. You maybe able to get to a 235 if you go high enough profile. Your car will have enough room for that width, just not on that rim.
Jazzer
Un-Official Suspension Guide | Choosing a new tire | Brakes upgrade ~ Speeding up slowing down | T-3650 ~ T-56 swap | Jazzer The Ego HD Vids
Tire and Wheel Fitment Guide | C/A Livernois beast build
Man those are some fantastic milk transporting devices... "
Old December 26th, 2008, 12:47 PM   #3
MyGT's Avatar
13.1@105
iTrader: 6 reviews
Jazzer
Really? I'm hoping sweet2kstang will chime in seeing as he has used the v6 wheels before.
Thanks Brees!
Old December 26th, 2008, 01:03 PM   #4
Proud American
MustangMatt96GT's Avatar
i have put 265s on a 17x7 before... the expedition had 17x7s stock and it has 265s on it now.
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
Never Lift Racecars
Old December 26th, 2008, 02:54 PM   #5
3rd Place '11 ROTY
19.34@42.259
If you had a high enough profile, maybe 60 series or something, you may find and acceptable fit, but wouldn't run such a tire on a Stang.
I have no doubt some have run a 275/35 or 40 series tire on a 7" wheel, but bad idea. No above tire I have seen is rated for such a narrow wheel and will stress the sidewall and have poor handling characteristics.
On another note, I have seen a 315 on an 8" wheel reciently and was horrible!
Jazzer
EDIT: I just checked out Nitto homepage real quick like. I found one of their lower end tires in a 275/55/20" rated for a 7.5" wheel. I don't see one finding a lower profile tire in a 275 rated for a 7" wheel, maybe I am wrong.
Old December 26th, 2008, 02:58 PM   #6
MyGT's Avatar
13.1@105
iTrader: 6 reviews
Jazzer
It'll be more of a track wheel, they will not be on for the street. If it's not safe I won't get them.
Thanks Brees!
Old December 26th, 2008, 03:02 PM   #7
3rd Place '11 ROTY
19.34@42.259
Now, if you are looking for a DR or launch tire, that can be a different story. I have no real experience with them, but know they tend to be rated for large contact patch and high profile for sidewall wrinkle.
Look around and see what you find. If it is not for the street, I think you will find something that will fit this need.
HTH
Jazzer
Old December 26th, 2008, 03:09 PM   #8
MyGT's Avatar
13.1@105
iTrader: 6 reviews
HTH
Jazzer
Thanks! I'm hoping someone will chime in with some experience with this application
Thanks Brees!
Old December 27th, 2008, 09:03 AM   #9
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
i am guessing you are talking about a 275/60/15 555r. it will fit, although i suggest something a little wider. a radial tire will be stiffer on the side walls and try to keep its form. a bias ply is more forgivable with a little bit of a narrow wheel. i was running a 10.50 with a 9in tread section. the 275 is a wider tread section and really needs at least an 8in wheel, but will work on something a little smaller. air pressure will have to be close to exact to keep the tire from cupping or only using center section of tread. if you want to run a v6 wheel for track only, i reccomend going with a bias tire. not only will it fit better, it will stick harder and absorb initial shock on launch. you also have to remember to watch what you buy to mount on the wheel as well. your wheel width should be +/- 1.5-2in of the tread section width.
Old December 27th, 2008, 09:48 AM   #10
MyGT's Avatar
13.1@105
iTrader: 6 reviews
Thanks for your input! I'm going to try and find a different pair.
Thanks Brees!
Threads Similar to: Nitto 275s on 15x7 Wheel
nitto 555r vs. nitto NT01 xXJayManZXx17 99-04 8 September 27th, 2008 08:02 PM
275s paulgt General Tech 3 November 12th, 2007 08:32 PM
275s Timm10221 Modular Mustangs 31 October 18th, 2007 07:51 PM
Nitto help MSO The Clubhouse 132 July 18th, 2007 12:13 PM
