Power seat problem need help!!!
Old December 26th, 2008, 06:18 PM   #1
2001 Mustang Bullitt
bullitt01 is on a distinguished road
Ok, my GT all the sudden while I was cleaning my car and had the seat up blew the fuse under the hood so now everytime I try puttin a new fuse in it blows. I tried unhooking the battery then puttin in the fuse don't work just blows when the power comes back, tried unhooking the switch and it does the same thing just pops when I hook the wire back up. I can't drive my car now cause the seat is too far up.......can anyone tell me what might be the problem????
Old December 26th, 2008, 07:06 PM   #2
3rd Place '11 ROTY
Jazzer The Cat's Avatar
'02 GR-40/SLA Saleen
19.34@42.259
Jazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant future
Sounds like you got some cleaning fluid inside the motor or something under seat. You have a "dead-short" their somewhere.
Start by disconnecting the power cable under the seat leading to the motor. Now install a new fuse. If it does NOT blow, you have a short somewhere AFTER the point of power connection under the seat. Look around and see if you damaged some wires or got cleaning solution inside a power box. You MAY be able to get lucky and just dry everything out and get 'er goin'.
Good luck!
HTH
Jazzer
Un-Official Suspension Guide | Choosing a new tire | Brakes upgrade ~ Speeding up slowing down | T-3650 ~ T-56 swap | Jazzer The Ego HD Vids
Tire and Wheel Fitment Guide | C/A Livernois beast build
Man those are some fantastic milk transporting devices... "
Old December 27th, 2008, 08:17 PM   #3
I have another question I read on the net that you can run a hot wire to the seat to make it move, can anyone tell me how to do that so that I can at least put the seat back to where I can drive it.
Old December 27th, 2008, 08:45 PM   #4
3rd Place '11 ROTY
19.34@42.259
If the motor has some type of electrical short, which I believe it does, you will have the same result.
Did you try my above test?
Jazzer
Old December 27th, 2008, 09:09 PM   #5
Yea I tried that the fuse wont blow until I hook the power cable back to the seat.
Old December 27th, 2008, 09:52 PM   #6
3rd Place '11 ROTY
19.34@42.259
OK, your issue is within the seat electrical components. Running a new power wire WILL NOT get the seat to move and will likely scare the bejesus out of you when it arcs and completely blows the electronics within the seat. DON'T do this!!!
You will likely need to completely remove the seat to figure out what happened. I believe you got some Windex or leather cleaner in the components. You just MAY get lucky and be able to dry off a circuit board to solve your issue. You may also find a bent 12vt "+" connection touching a ground point ("-" connection) on seat frame or something.
HTH
Jazzer
If you need to, take the seat out and PM me some pics. Will be happy to help you figure out what is happening as The Jazzer's gotcha back
Old December 27th, 2008, 10:27 PM   #7
Jazzer I sent you a PM so let me know if you got it
Old December 27th, 2008, 11:33 PM   #8
Moderator
03SonicBoom's Avatar
2003 Grand Cherokee
03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of
Sounds like it's time to break out the DMM and wring out the short.
Threads Similar to: Power seat problem need help!!!
Passeger Power Seat Goldcomet 2005 - 2010 3 May 2nd, 2008 02:19 PM
power seat not working bcnsucks 94-95 6 April 19th, 2008 10:07 AM
How to fix my power seat? 94pacecarSVT 94-95 5 April 8th, 2008 06:25 PM
Passenger power seat greentea 2005 - 2010 1 August 12th, 2007 01:08 PM
Power seat ? fogged306 5.0 Mustangs 3 May 22nd, 2007 12:54 AM
