Can I put a stock 04 supercharger in a 99 cobra
Old December 28th, 2006, 02:12 AM   #1
cobra.jz is on a distinguished road
I got a 04 cobra and i'm going to get a HP turbo kit for it and I wont to know if i can put my stock supercharger in a 99 cobra that my friend just got it looks like I can but I dont know (halp me)
Old December 28th, 2006, 11:15 AM   #2
GTSilver is on a distinguished road
i think you might be able to cuz its a 4 valver...i dont see why not...the only thing is you gotta keep the boost lower cuz the block on the 99 cobra is aluminum and the compression is also higher on the 99...the 03-04 cobras have cast iron blocks(stronger than aluminum) i think less aggressive cams and lower compression to aquire the blower better.
2002 GT
K&N CAI
O/R X-Pipe
Race Bullit Mufflers
SCT Xcal2 w/Custom Tune By RWTD
4.10 Rear
Nitto D/R's
FR500 Rims 17x9 17x10.5
Old December 29th, 2006, 04:52 AM   #3
cool!!! we are going to see if we can do it when I get my turbo kit soon how much hp!! Do you think we will get on the 99 cobra we hope we get like 400 to 500 do you think we will?
Old December 29th, 2006, 11:37 AM   #4
base line for you car is 320 at the crank....10psi your gonna prolly get in the high 400's if not at 500...i could be wrong...dont take my word for it...get more research done...find out if it actually does fit...it might and it might not
2002 GT
K&N CAI
O/R X-Pipe
4.10 Rear
Nitto D/R's
Old December 29th, 2006, 06:01 PM   #5
matrixpuba is on a distinguished road
Send a message via AIM to matrixpuba Send a message via MSN to matrixpuba Send a message via Yahoo to matrixpuba
500?
better get the fuel system in order 1st
Old December 29th, 2006, 08:45 PM   #6
MSTGGT00 is on a distinguished road
Send a message via AIM to MSTGGT00
+1 on matrix. You can seriously probably get about 5 out of it, but you def. better start looking into a fuel system otherwise your not going to like the results as much as you could.
Originally Posted by texas_mustang
MSTGGT00 wrote:
If my kids try and drive hondas. Ill send them to mexico in a basket.
Old December 31st, 2006, 05:12 AM   #7
ya I need to look in to the fuel sytem and the alternatar to it's in the way of the supercharger i hope it will fit ..Sorry about the spelling i just got home from seeing the ufc fight and i'm a bit f#$% up :award and no!! i did not drive.. i love my stang but hit me up so i know what you think ..and not about me being f@#$ up :award ..ok if you wont j/k seee ya
Old December 31st, 2006, 09:46 PM   #8
blown03mach1 is on a distinguished road
There is more to it then swapping the S/C over. You would neeed to do the entire intake system as well. This means upper, intercooler, and lower. All the cooler hardware needs swapped over as well. Obviously the injectors need replaced as well as the fuel supply system as pointed out previously. As far as numbers, I would guess with an agressive tune you would pull a mid 400 out of it unless you pullied the hell out of it, but at that number your 99 cobra is near breaking its rods anyway. Remember the stock 03/04 was only rated 390 at the crank. IMHO there is a lot of wokr involved, but it sounds like the price is right and you will get that NASTY Eaton whine under WOT!!!! God I love that sound.
Good luck.
I just got to thinking, the 03/04 and 99 Cobras use different heads. I assume that the 03 intake would bolt to the 99, but I am not 100% on that.
Old December 31st, 2006, 10:00 PM   #9
Good luck.
actually the 99+ 4v heads are all the same. i work for teksid and make the heads for the 2 and 4 v cars
Old December 31st, 2006, 10:32 PM   #10
I thought that the 03/04 Cobra and Mach heads were the best flowing heads since the Cobra R (from the factory). Is the difference just cams and or valve size as well? I know they are not the same, maybe the same casting though.
BTW can you get me an older 4.6 Teksid block? J/K
Old January 1st, 2007, 12:02 AM   #11
i can get the aluminum teksid block, but you will pay alot for shipping from Italy lol the cobra r heads are a different casting as are a set of fr500 heads.
on the 2v heads, they are all the same. believe it or not, the roush mustangs have the same castings, but we dip some parts for a smother intake and exhaust port.
Old January 1st, 2007, 12:46 PM   #12
Cool, thanks for correcting me. I always thought the 99/01 were different. It maybe just the internals inside the heads that were different then.
Threads Similar to: Can I put a stock 04 supercharger in a 99 cobra
1996 cobra swap with 03 cobra heads and supercharger. stan's96snake 96-98 14 October 30th, 2010 03:57 PM
STOCK 00GT W/410'S VS 03 COBRA STOCK spero 99-04 35 March 22nd, 2009 07:00 AM
Supercharger on stock engine klindz500 99-04 12 May 26th, 2007 01:15 PM
stock with supercharger 9stang1 5.0 Mustangs 2 January 4th, 2007 10:11 PM
Supercharger on stock bottom? 95StangSVT 5.0 Mustangs 2 October 19th, 2006 09:34 PM
