| View Poll Results: Vortech & Cams OR Vortech & After/Intercooler | |||
| Vortech & Cams |
3 | 15.00% |
15 | 75.00% |
| Other (please specify) |
2 | 10.00% |
| Voters: 20. You may not vote on this poll | |||
Hi guys...
so my goal is 410 to 420 to the wheels.... which option would be better for a daily driver...i have 66K on the engine and car.....please give specifics thanks all!!
2004 GT....4.10s, SCT X Cal2, BBK Lts, BBK O/R Xpipe, Flowmaster catback with Super 40 mufflers, BBK 75mm TB & Plenum, K&N Filter w/no silencer, Steeda UDP, Steeda TriAx, and Steeda G-Trac stages 1, 2, 3, and 4, blower is on the way!!! |
12.73@111.36
From what I've read you would want both an intercooler and cams. If you can only do one or the other right now, I would pick the intercooler first.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370 Mods list in Garage. |
I run a Vortech with a Paxton air/air intercooler
both
http://www.cardomain.com/ride/3112249 |
One Man Wolf Pack
A Novi 2000 with MPH blower cams.
![]() ΜΟΛΩΝ ΛΑΒΕ
Boost gets you laid
you don't want a non intercooled car with cams, you will fuck that shit up. 400 is pushing it on a non intercooled setup
![]() '01 GT. Just a couple Bolt-ons. 0rwhp 0rwtq. Epic Turbo build in progress 2003 Rubicon (wheelin rig) 2008 Silverado 4x4 (towin rig/road queen) 2009 KTM 450 XC-W (Brap Brap!) |
Vortech V2 Si
Boost gets you laid
is that what you have on yours hardhitter? i would be very weary of putting that interooler on my car. i just think its cheap and shitty, probably doesn't do much except look cool
#9 | |
I made 440 with a FMIC and a stock long block and exhaust manifolds w/ 10lbs.. If you're looking for solid safe number then go with the A/C or even a FMIC if you want to go cheaper. Cool the charge before anything else. |
those ebay intercoolers are cheap , probably dont fit the best but as long as you can fab them up and they dont leak I am sure they are alot better than nothing at all
why do u prefer the air to air over vortechs Aftercooler?
how will it hurt it?
Boost gets you laid
because that hot air with that much power is a recipe for detonation.. it just puts a ton of stress on your engine with all that hot air and power.
makes sense...thanks
#15 | |
12.777@115JLT;Prochamber;Magnapacks;4.10s;31 Spline;Spec Stage 2+;Predator;NX 125Shot .. Quest for 11s |
water/air coolers are more prone to heat soak in traffic , air/air if its large enough will not heat soak in traffic as bad and will recoup after getting hot after getting in clean air for about 1-2 minutes of driving at about 55 mph ......water/air will take up to 10 minutes to cool back down after being in heavier traffic
#17 | |
was it hard to make the Paxton intercooler fit with the vortech? do you have any pics?
I am not a fan of after coolers either, for your particular I would run air to air. When I did the turbo on my old 96 I made all the hot and cold piping and used V bands. I'll see if i can find the link for the company I used to purchase a the prebent tubing for the cold side.
I run the Vortech with an Air to Water cooler..the extra power gained is definitely worth it.
Use and aftercooler then do the cams later....IMO
Threads Similar to: Vortech & Cams OR Vortech & After/Intercooler
| anybody running paxton or vortech w/o intercooler | RainsFather | 2005 - 2010 | 14 | August 26th, 2008 01:14 AM |
| MPH's Vortech mongoose kit w/ paxton intercooler | bbk03gt24 | 99-04 | 5 | July 9th, 2008 07:58 PM |
| Vortech R&D team needs these | homebrewed | The Clubhouse | 24 | May 12th, 2008 10:02 PM |
| Front mount intercooler for vortech sc? | supercharged03gt | 99-04 | 15 | January 13th, 2008 08:07 PM |
