water crossover on intake manifold leaking coolant
Is the only option for fixing a coolant leak because of a crack near the termostat housing a new intake manfold?
Vortech V2 Si
Resident DJ
'01 Cobra Vert.
Yeah, mine cracked/blew and I got a new one with the aluminum crossover.
Anyone know of a good upgrade for supercharged applications?
Is this any good: Edelbrock 2838 - Edelbrock Victor Jr. Intake Manifolds - summitracing.com
Vortech V2 Si
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 4 reviews
Yea. You can usually find them pretty cheap on ebay I think. New manifold,gaskets, and a few hours of time at most youll be back in business.
#5 | |
What kind of gain if I have 420hp now?
Vortech V2 Si
On the stock shortblock? Personally id stick the $800 the p51 costs towards a forged bottom end before going with more power. Each to their own though. As far as gains go I havent a clue, I dont care much for them/look into them much although I do believe its in the upper rpm range and thats about all.
You could also go with a typhoon. Theyre pretty much the same as factory just all metal and cost about $500. So weather thats worth it or not would be up to you. Last edited by ajm; January 5th, 2009 at 12:18 AM. |
so are the dorman ones from the auto parts store okay
or should i get this or are they the same Ford Racing M-9424-P46 - Ford Racing 4.6L Performance Improvement Intake Manifolds - summitracing.com
Vortech V2 Si
Itll be fine although id try to find an oem/ford one for the same price if possible, then again im a bit picky about aftermarket/oem replacement stuff whereas some people dont care as long as itll do.
so im guessing go with the ford racing one.. can the gaskets be reused?
Vortech V2 Si
13.86@100.3
no get new gaskets and u can get ford racing one from american muscle. i had same issue w my 2000
2004 40th Anniversary GT Pro 5.0 Shifter Lowered(H&R Springs) Summit Hpipe w Dynomax weldin mufflers Minor odds and ends |
Threads Similar to: water crossover on intake manifold leaking coolant
| Leaking Coolant | saltydog_NM | 5.0 Mustangs | 4 | September 30th, 2008 07:38 PM |
| Leaking coolant,hot climate, not good | zinc76 | 99-04 | 14 | May 9th, 2007 07:30 AM |
| HELP!!! Coolant leaking out exhaust.... | lwhitetrash88l | V6 Mustangs | 23 | April 6th, 2007 02:40 PM |
| coolant leaking here i think. | YNOT | 5.0 Mustangs | 20 | March 22nd, 2007 10:18 PM |
| coolant crossover tube | daleboeski | 96-98 | 5 | August 13th, 2006 06:52 PM |
