Nitrous express kit!!!
yesterday i decided to buy an nx kit to run on my set up because i got a killer deal at one of my local shops. i am trying to dip into 12s for the summer so i can beat my ls1 friends and shut them up for once. the best time run by them was a 12.9. is there anything i should know about running nitrous at the track? when to shoot it? what i will need? how to keep traction? best suspension mods for traction? i plan on running a 100 shot.
2003 Mustang GT
12.61@108
ive got the NX base kit running a 75shot. I engage it by the push button (not throttle switch) If the track is good Ill hit it at 2000rpm (NX's recommended miniumum rpm) but if the track sucks I'll wait until I dont hear the tires screaching anymore. Id go one step colder plugs with a 100shot unless you've got a tuner. And always use 93+fuel, and a warm bottle makes a difference
![]() *FOR SALE* Nitrous Express Kit, Summit O/R H-Pipe, Flowmaster American Thunder, BBK Subframe Connectors, Eibach Pro-Kit, Summit Rear Control Arms, 4.10 gears, SCT SF3, Nitto 555r's, and its an automatic. 240/277 N/A |
whats your best time on the nitrous?
6.82@100mph 1.45 60'
i have run 12.0 on nitrous... you need drag radials... my kit is set up with a wot switch... when i go full throttle it sprays... what all came with your kit? how much money do you wanna put into it? how long you gonna keep it?
2003 Mustang GT
12.61@108
13.30@104 2.02 60ft on a hookin good track. Thats with just the 75shot, exhaust, and street tires
what was your bottle pressure on that pass? doesnt sound like it was sprayin correctly
Proud American
+1 i know when my 100 shot hit.... hwolly shit... if i was not on the track, it would spin the slicks even at 13 PSI... 1200 PSI pressure on the bottle, WOT, 3000-5600 window. I went from 14.6 best n/a to a 13.25 at the same wieght... now i did a get constant 12s, but it took some nice wieght reductiont too
mine ran 12.17 on the 100 shot with about 1100lbs in the bottle... that was just with 100 shot, exhaust, pulleys and tires... added a 125hp shot, 31 spline axles, 3.73 gears, slicks and skinnies and only dropped .17... i picked up 3mph though... should see 11s after i get my dang differential back together... matt what brand is your differential? where you get it? how much?
2003 Mustang GT
12.61@108
It was prolly a little low. I dont have a gauge or bottle warmer (yet)
#10 | |
Proud American
i plan on running slicks with skinnies in the front. i plan on running a bottle warmer, maybe a window switch. im not sure how long i will keep it. should i do it with a wot switch?? or should i do a push button?
I would use a WOT switch. Just make sure that if you do use a push-button that its run through a WOT switch so you don't accidentally hit the button while you're idling. A really good tune-able setup would be a wot switch and a window switch.
Black 2001 SVT Cobra Solid axle "Good judgment comes from experience, experience comes from bad jugment" MM Cobra Club Member #1 |
Proud American
window switch and wot switch FTW
i would need a window switch if i wanted to powershift right??
Yes. You don't want to hit your rev limiter while you're spraying. Bad things will happen.
how are the electronics from dynotune nitrous? i was thinking of ordering a bottle warmer and tps/window switch from them. would be only 200 dollars.
I have no experience with Dynotune. I tend to try and use the same brand for a system. I had a Nitrous Express kit on my 94 with the NX purge kit and NX fully automatic bottle heater. NX has a very good reputation. Dynotune, I dont know.
wait til i get my kit kyle...a nice brother vs brother nitrous battle is def happenin at epping bitch lol
03 GT: Totaled 2000 Ford F-150 Triton V8:F'd in the A 1999 Plymouth Voyager: The BangBus Topless Mustang Club Member |
Proud American
i use the MSD window switch but i have the dynotune nitrous bottle heater, and it works great.... pressure regulated...
2000 mustang gt
dynotune is a great company
Threads Similar to: Nitrous express kit!!!
| nitrous express | mrnewall | 99-04 | 10 | May 6th, 2007 06:45 AM |
| Nitrous Express Install Videos | 99mustang232 | General Tech | 1 | November 27th, 2005 07:20 PM |
